change 1-wire slave search/scan time
Go to solution Solved by nedoskiv,
Hello after some search i successfull attack Ibutton on 1 wire, using ibutton probe
my problem is that by default kernel scan for slaves every 10 seconds.  Want to change it to 1 second or less if possible.
Searching a bit, on some linux distributions this solves the problem:
modprobe wire timeout=1 slave_ttl=5
modprobe w1-gpio
but since in arbian  /arbianEnv.txt take care of modules loaded, it do not work, My current file is:
verbosity=1
bootlogo=false
console=serial
disp_mode=1920x10[D80p60
overlay_prefix=sun8i-h3
overlays=i2c0 pps-gpio uart1 uart2 uart3 usbhost1 usbhost2 w1-gpio
param_pps_pin=PA6
param_w1_pin=PC3
rootdev=UUID=6dee376a-a115-473b-939b-b91774c75fa8
rootfstype=ext4
I have tried to add:
param_w1_timeout=1
param_wire_timeout=1
and some other - unsuccessfull
I need some help, thanks in advance :)
  • Solution
here is the part of my rc.local that do the trick for me
rmmod w1_gpio
rmmod wire
modprobe wire timeout=0 timeout_us=200000 slave_ttl=3
modprobe w1_gpio
since that works, I assume one wire overlay parameter "param_w1_pin=PC3" was keep somewhere and is passed when I load module again.
