While setting up my clearfog pro with armbian I noted the pppoe module is not compiled or available to download for my kernel using apt-get.
What is the recommended approach here? do I need to compile my own kernel?
Thanks,
Gustavo
PPPoE module was added to both kernel configurations for Clearfog, it will be available in the next update or you can download and install kernel packages manually from beta.armbian.com after next rebuild. Or you can try building the kernel by yourself if you want.
