Jimbo555 Posted October 30, 2016 Posted October 30, 2016 Hi! I have a MiniX device on the A20 processor. It is very similar to cubieboard 2, but has no ethernet input. I downloaded the firmware from cubieboard 2 (Armbian_5.20_Cubieboard2_Debian_jessie_3.4.112_desktop.img), recorded on the sdcard. Firmware starting, but stops on the line : loading, please wait. I waited more than 20 minutes but nothing changed... I am Attaching the script file.fex which has been with this device. Help to understand what the problem is, thanks. script.fex https://drive.google.com/open?id=0B-6BIQC_H2vla0ljYnBiYXMtNGc It is very similar to this, the CPU only and the other is a20 1Gb ram, 4Gb nand http://linux-sunxi.org/Pineriver_H24 Second run
Jimbo555 Posted October 31, 2016 Author Posted October 31, 2016 I think that the problem is due to script which listens for connections on the network (obtain ip address). rompt where it is possible to disable, but I can't find it. Just get there ip, and the system simply will not boot... the Problem is small, but very large losses
Jimbo555 Posted November 2, 2016 Author Posted November 2, 2016 I was able to start the system, but on version Armbian_5.10_Cubieboard2_Debian_jessie_4.5.2_desktop. And I was able to upgrade to the latest version. Here is the dmesg log if you're interested [ 0.000000] Booting Linux on physical CPU 0x0 [ 0.000000] Linux version 4.8.4-sunxi (root@xenial) (gcc version 5.4.0 20160609 (Ubuntu/Linaro 5.4.0-6ubuntu1~16.04.1) ) #6 SMP Sun Oct 23 15:55:47 CEST 2016 [ 0.000000] CPU: ARMv7 Processor [410fc074] revision 4 (ARMv7), cr=10c5387d [ 0.000000] CPU: div instructions available: patching division code [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache [ 0.000000] OF: fdt:Machine model: Cubietech Cubieboard2 [ 0.000000] cma: Reserved 16 MiB at 0x7e400000 [ 0.000000] Memory policy: Data cache writealloc [ 0.000000] On node 0 totalpages: 259444 [ 0.000000] free_area_init_node: node 0, pgdat c0fa5bc0, node_mem_map ef70a000 [ 0.000000] Normal zone: 1728 pages used for memmap [ 0.000000] Normal zone: 0 pages reserved [ 0.000000] Normal zone: 196608 pages, LIFO batch:31 [ 0.000000] HighMem zone: 62836 pages, LIFO batch:15 [ 0.000000] psci: probing for conduit method from DT. [ 0.000000] psci: Using PSCI v0.1 Function IDs from DT [ 0.000000] percpu: Embedded 15 pages/cpu @ef6c1000 s30028 r8192 d23220 u61440 [ 0.000000] pcpu-alloc: s30028 r8192 d23220 u61440 alloc=15*4096 [ 0.000000] pcpu-alloc: [0] 0 [0] 1 [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 257716 [ 0.000000] Kernel command line: console=tty1 root=/dev/mmcblk0p1 rootwait rootfstype=ext4 cgroup_enable=memory swapaccount=1 sunxi_ve_mem_reserve=0 sunxi_g2d_mem_reserve=0 sunxi_no_mali_mem_reserve sunxi_fb_mem_reserve=16 hdmi.audio=EDID:0 disp.screen0_output_mode=1920x1080p60 panic=10 consoleblank=0 enforcing=0 loglevel=1 [ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes) [ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes) [ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes) [ 0.000000] Memory: 991636K/1037776K available (10240K kernel code, 703K rwdata, 2008K rodata, 1024K init, 308K bss, 29756K reserved, 16384K cma-reserved, 234960K highmem) [ 0.000000] Virtual kernel memory layout: vector : 0xffff0000 - 0xffff1000 ( 4 kB) fixmap : 0xffc00000 - 0xfff00000 (3072 kB) vmalloc : 0xf0800000 - 0xff800000 ( 240 MB) lowmem : 0xc0000000 - 0xf0000000 ( 768 MB) pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB) modules : 0xbf000000 - 0xbfe00000 ( 14 MB) .text : 0xc0008000 - 0xc0b00000 (11232 kB) .init : 0xc0e00000 - 0xc0f00000 (1024 kB) .data : 0xc0f00000 - 0xc0faffcc ( 704 kB) .bss : 0xc0fb1000 - 0xc0ffe250 ( 309 kB) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1 [ 0.000000] Hierarchical RCU implementation. [ 0.000000] Build-time adjustment of leaf fanout to 32. [ 0.000000] RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=2. [ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=32, nr_cpu_ids=2 [ 0.000000] NR_IRQS:16 nr_irqs:16 16 [ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 24.00MHz (phys). [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns [ 0.000007] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns [ 0.000020] Switching to timer-based delay loop, resolution 41ns [ 0.000654] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns [ 0.000940] clocksource: hstimer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 12741736309 ns [ 0.001377] Console: colour dummy device 80x30 [ 0.001396] console [tty1] enabled [ 0.001426] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000) [ 0.001440] pid_max: default: 32768 minimum: 301 [ 0.001635] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes) [ 0.001645] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes) [ 0.002658] CPU: Testing write buffer coherency: ok [ 0.002722] ftrace: allocating 31010 entries in 91 pages [ 0.057330] /cpus/cpu@0 missing clock-frequency property [ 0.057349] /cpus/cpu@1 missing clock-frequency property [ 0.057367] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000 [ 0.057406] Setting up static identity map for 0x40100000 - 0x40100058 [ 0.060057] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001 [ 0.060192] Brought up 2 CPUs [ 0.060205] SMP: Total of 2 processors activated (96.00 BogoMIPS). [ 0.060210] CPU: All CPU(s) started in HYP mode. [ 0.060213] CPU: Virtualization extensions available. [ 0.061334] devtmpfs: initialized [ 0.078879] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 4 [ 0.079275] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns [ 0.080293] xor: measuring software checksum speed [ 0.177012] arm4regs : 1130.400 MB/sec [ 0.277082] 8regs : 787.200 MB/sec [ 0.377158] 32regs : 764.400 MB/sec [ 0.477239] neon : 1143.200 MB/sec [ 0.477245] xor: using function: neon (1143.200 MB/sec) [ 0.477383] pinctrl core: initialized pinctrl subsystem [ 0.478767] NET: Registered protocol family 16 [ 0.480330] DMA: preallocated 256 KiB pool for atomic coherent allocations [ 0.517337] cpuidle: using governor ladder [ 0.557358] cpuidle: using governor menu [ 0.557891] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers. [ 0.557898] hw-breakpoint: maximum watchpoint size is 8 bytes. [ 0.737790] raid6: int32x1 gen() 159 MB/s [ 0.907865] raid6: int32x1 xor() 146 MB/s [ 1.078057] raid6: int32x2 gen() 192 MB/s [ 1.248344] raid6: int32x2 xor() 156 MB/s [ 1.418651] raid6: int32x4 gen() 198 MB/s [ 1.588688] raid6: int32x4 xor() 155 MB/s [ 1.758922] raid6: int32x8 gen() 185 MB/s [ 1.928951] raid6: int32x8 xor() 127 MB/s [ 2.099241] raid6: neonx1 gen() 447 MB/s [ 2.269317] raid6: neonx1 xor() 328 MB/s [ 2.439534] raid6: neonx2 gen() 587 MB/s [ 2.609706] raid6: neonx2 xor() 426 MB/s [ 2.779898] raid6: neonx4 gen() 651 MB/s [ 2.950079] raid6: neonx4 xor() 450 MB/s [ 3.120329] raid6: neonx8 gen() 626 MB/s [ 3.290427] raid6: neonx8 xor() 435 MB/s [ 3.290432] raid6: using algorithm neonx4 gen() 651 MB/s [ 3.290436] raid6: .... xor() 450 MB/s, rmw enabled [ 3.290442] raid6: using intx1 recovery algorithm [ 3.290809] reg-fixed-voltage ahci-5v: could not find pctldev for node /soc@01c00000/pinctrl@01c20800/ahci_pwr_pin@0, deferring probe [ 3.290862] reg-fixed-voltage usb1-vbus: could not find pctldev for node /soc@01c00000/pinctrl@01c20800/usb1_vbus_pin@0, deferring probe [ 3.290898] reg-fixed-voltage usb2-vbus: could not find pctldev for node /soc@01c00000/pinctrl@01c20800/usb2_vbus_pin@0, deferring probe [ 3.293138] SCSI subsystem initialized [ 3.293513] libata version 3.00 loaded. [ 3.293892] usbcore: registered new interface driver usbfs [ 3.293965] usbcore: registered new interface driver hub [ 3.294049] usbcore: registered new device driver usb [ 3.294339] media: Linux media interface: v0.10 [ 3.294394] Linux video capture interface: v2.00 [ 3.294480] pps_core: LinuxPPS API ver. 1 registered [ 3.294485] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> [ 3.294507] PTP clock support registered [ 3.294672] Linux cec interface: v0.10 [ 3.296510] clocksource: Switched to clocksource arch_sys_counter [ 3.360646] VFS: Disk quotas dquot_6.6.0 [ 3.360745] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes) [ 3.361901] simple-framebuffer 7f574000.framebuffer: framebuffer at 0x7f574000, 0xa8c000 bytes, mapped to 0xf0900000 [ 3.361915] simple-framebuffer 7f574000.framebuffer: format=x8r8g8b8, mode=2560x1080x32, linelength=10240 [ 3.410757] Console: switching to colour frame buffer device 320x67 [ 3.458341] simple-framebuffer 7f574000.framebuffer: fb0: simplefb registered! [ 3.469923] NET: Registered protocol family 2 [ 3.470785] TCP established hash table entries: 8192 (order: 3, 32768 bytes) [ 3.470874] TCP bind hash table entries: 8192 (order: 4, 65536 bytes) [ 3.471000] TCP: Hash tables configured (established 8192 bind 8192) [ 3.471107] UDP hash table entries: 512 (order: 2, 16384 bytes) [ 3.471169] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes) [ 3.471436] NET: Registered protocol family 1 [ 3.472143] RPC: Registered named UNIX socket transport module. [ 3.472152] RPC: Registered udp transport module. [ 3.472156] RPC: Registered tcp transport module. [ 3.472159] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 3.472496] Trying to unpack rootfs image as initramfs... [ 3.760290] Freeing initrd memory: 4072K (c9c06000 - ca000000) [ 3.761102] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 5 counters available [ 3.762462] futex hash table entries: 512 (order: 3, 32768 bytes) [ 3.763133] Initialise system trusted keyrings [ 3.763703] workingset: timestamp_bits=14 max_order=18 bucket_order=4 [ 3.773646] zbud: loaded [ 3.777478] NFS: Registering the id_resolver key type [ 3.777525] Key type id_resolver registered [ 3.777530] Key type id_legacy registered [ 3.777548] nfs4filelayout_init: NFSv4 File Layout Driver Registering... [ 3.777553] Installing knfsd (copyright (C) 1996 okir@monad.swb.de). [ 3.779336] JFS: nTxBlock = 7906, nTxLock = 63255 [ 3.790834] SGI XFS with ACLs, security attributes, realtime, no debug enabled [ 3.800277] Key type asymmetric registered [ 3.800376] bounce: pool size: 64 pages [ 3.800714] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247) [ 3.800906] io scheduler noop registered [ 3.800913] io scheduler deadline registered [ 3.801344] io scheduler cfq registered (default) [ 3.802253] sun4i-usb-phy 1c13400.phy: could not find pctldev for node /soc@01c00000/pinctrl@01c20800/usb0_id_detect_pin@0, deferring probe [ 3.805689] sun7i-a20-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver [ 3.883941] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled [ 3.907901] 1c28000.serial: ttyS0 at MMIO 0x1c28000 (irq = 45, base_baud = 1500000) is a U6_16550A [ 3.908857] [drm] Initialized drm 1.1.0 20060810 [ 3.913558] brd: module loaded [ 3.922577] loop: module loaded [ 3.924186] libphy: Fixed MDIO Bus: probed [ 3.925027] sun7i-dwmac 1c50000.ethernet: no regulator found [ 3.925107] sun7i-dwmac 1c50000.ethernet: no reset control found [ 3.925115] Ring mode enabled [ 3.925120] DMA HW capability register supported [ 3.925126] Normal descriptors [ 4.098094] libphy: stmmac: probed [ 4.098113] eth0: PHY ID 0000ffff at 0 IRQ POLL (stmmac-0:00) active [ 4.098121] eth0: PHY ID 0000ffff at 1 IRQ POLL (stmmac-0:01) [ 4.098128] eth0: PHY ID 0000ffff at 2 IRQ POLL (stmmac-0:02) [ 4.098134] eth0: PHY ID 0000ffff at 3 IRQ POLL (stmmac-0:03) [ 4.098140] eth0: PHY ID 0000ffff at 4 IRQ POLL (stmmac-0:04) [ 4.098146] eth0: PHY ID 0000ffff at 5 IRQ POLL (stmmac-0:05) [ 4.098151] eth0: PHY ID 0000ffff at 6 IRQ POLL (stmmac-0:06) [ 4.098157] eth0: PHY ID 0000ffff at 7 IRQ POLL (stmmac-0:07) [ 4.098163] eth0: PHY ID 0000ffff at 8 IRQ POLL (stmmac-0:08) [ 4.098168] eth0: PHY ID 0000ffff at 9 IRQ POLL (stmmac-0:09) [ 4.098174] eth0: PHY ID 0000ffff at 10 IRQ POLL (stmmac-0:0a) [ 4.098180] eth0: PHY ID 0000ffff at 11 IRQ POLL (stmmac-0:0b) [ 4.098186] eth0: PHY ID 0000ffff at 12 IRQ POLL (stmmac-0:0c) [ 4.098192] eth0: PHY ID 0000ffff at 13 IRQ POLL (stmmac-0:0d) [ 4.098198] eth0: PHY ID 0000ffff at 14 IRQ POLL (stmmac-0:0e) [ 4.098203] eth0: PHY ID 0000ffff at 15 IRQ POLL (stmmac-0:0f) [ 4.098209] eth0: PHY ID 0000ffff at 16 IRQ POLL (stmmac-0:10) [ 4.098215] eth0: PHY ID 0000ffff at 17 IRQ POLL (stmmac-0:11) [ 4.098221] eth0: PHY ID 0000ffff at 18 IRQ POLL (stmmac-0:12) [ 4.098226] eth0: PHY ID 0000ffff at 19 IRQ POLL (stmmac-0:13) [ 4.098232] eth0: PHY ID 0000ffff at 20 IRQ POLL (stmmac-0:14) [ 4.098238] eth0: PHY ID 0000ffff at 21 IRQ POLL (stmmac-0:15) [ 4.098244] eth0: PHY ID 0000ffff at 22 IRQ POLL (stmmac-0:16) [ 4.098250] eth0: PHY ID 0000ffff at 23 IRQ POLL (stmmac-0:17) [ 4.098256] eth0: PHY ID 0000ffff at 24 IRQ POLL (stmmac-0:18) [ 4.098261] eth0: PHY ID 0000ffff at 25 IRQ POLL (stmmac-0:19) [ 4.098268] eth0: PHY ID 0000ffff at 26 IRQ POLL (stmmac-0:1a) [ 4.098273] eth0: PHY ID 0000ffff at 27 IRQ POLL (stmmac-0:1b) [ 4.098279] eth0: PHY ID 0000ffff at 28 IRQ POLL (stmmac-0:1c) [ 4.098285] eth0: PHY ID 0000ffff at 29 IRQ POLL (stmmac-0:1d) [ 4.098291] eth0: PHY ID 0000ffff at 30 IRQ POLL (stmmac-0:1e) [ 4.098296] eth0: PHY ID 0000ffff at 31 IRQ POLL (stmmac-0:1f) [ 4.098642] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [ 4.098648] ehci-platform: EHCI generic platform driver [ 4.099132] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver [ 4.099176] ohci-platform: OHCI generic platform driver [ 4.099603] usbcore: registered new interface driver usb-storage [ 4.100896] sunxi-rtc 1c20d00.rtc: rtc core: registered rtc-sunxi as rtc0 [ 4.100907] sunxi-rtc 1c20d00.rtc: RTC enabled [ 4.101026] i2c /dev entries driver [ 4.102257] axp20x-i2c 0-0034: AXP20x variant AXP209 found [ 4.116468] input: axp20x-pek as /devices/platform/soc@01c00000/1c2ac00.i2c/i2c-0/0-0034/axp20x-pek/input/input0 [ 4.124552] random: fast init done [ 4.125390] axp20x-i2c 0-0034: Backup (RTC) battery charging is disabled [ 4.125599] axp20x-i2c 0-0034: AXP20X driver loaded [ 4.128839] sunxi-wdt 1c20c90.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0) [ 4.130646] sunxi-mmc 1c0f000.mmc: Got CD GPIO [ 4.196878] sunxi-mmc 1c0f000.mmc: base:0xf08f6000 irq:27 [ 4.198012] sunxi-mmc 1c11000.mmc: Got CD GPIO [ 4.243639] mmc0: host does not support reading read-only switch, assuming write-enable [ 4.246090] mmc0: new high speed SDHC card at address 0007 [ 4.247097] mmcblk0: mmc0:0007 SL16G 14.5 GiB [ 4.248909] mmcblk0: p1 [ 4.256889] sunxi-mmc 1c11000.mmc: base:0xf08fa000 irq:28 [ 4.258216] ledtrig-cpu: registered to indicate activity on CPUs [ 4.258339] hidraw: raw HID events driver (C) Jiri Kosina [ 4.258572] usbcore: registered new interface driver usbhid [ 4.258577] usbhid: USB HID core driver [ 4.259712] Initializing XFRM netlink socket [ 4.260605] NET: Registered protocol family 10 [ 4.261905] NET: Registered protocol family 17 [ 4.261939] NET: Registered protocol family 15 [ 4.261992] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this. [ 4.262057] 8021q: 802.1Q VLAN Support v1.8 [ 4.262121] Key type dns_resolver registered [ 4.262556] Registering SWP/SWPB emulation handler [ 4.263552] registered taskstats version 1 [ 4.263563] Loading compiled-in X.509 certificates [ 4.263674] zswap: loaded using pool lzo/zbud [ 4.265499] Btrfs loaded, crc32c=crc32c-generic [ 4.285804] Key type encrypted registered [ 4.346813] ahci-sunxi 1c18000.sata: PHY power up failed. [ 4.346991] ahci-sunxi: probe of 1c18000.sata failed with error -5 [ 4.347548] ehci-platform 1c14000.usb: EHCI Host Controller [ 4.347601] ehci-platform 1c14000.usb: new USB bus registered, assigned bus number 1 [ 4.348006] ehci-platform 1c14000.usb: irq 30, io mem 0x01c14000 [ 4.376535] ehci-platform 1c14000.usb: USB 2.0 started, EHCI 1.00 [ 4.376946] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002 [ 4.376956] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 4.376962] usb usb1: Product: EHCI Host Controller [ 4.376970] usb usb1: Manufacturer: Linux 4.8.4-sunxi ehci_hcd [ 4.376976] usb usb1: SerialNumber: 1c14000.usb [ 4.377902] hub 1-0:1.0: USB hub found [ 4.377985] hub 1-0:1.0: 1 port detected [ 4.378953] ehci-platform 1c1c000.usb: EHCI Host Controller [ 4.378995] ehci-platform 1c1c000.usb: new USB bus registered, assigned bus number 2 [ 4.379280] ehci-platform 1c1c000.usb: irq 34, io mem 0x01c1c000 [ 4.416529] ehci-platform 1c1c000.usb: USB 2.0 started, EHCI 1.00 [ 4.416926] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002 [ 4.416937] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 4.416943] usb usb2: Product: EHCI Host Controller [ 4.416950] usb usb2: Manufacturer: Linux 4.8.4-sunxi ehci_hcd [ 4.416956] usb usb2: SerialNumber: 1c1c000.usb [ 4.417832] hub 2-0:1.0: USB hub found [ 4.417913] hub 2-0:1.0: 1 port detected [ 4.418875] ohci-platform 1c14400.usb: Generic Platform OHCI controller [ 4.418921] ohci-platform 1c14400.usb: new USB bus registered, assigned bus number 3 [ 4.419189] ohci-platform 1c14400.usb: irq 31, io mem 0x01c14400 [ 4.490844] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001 [ 4.490856] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 4.490863] usb usb3: Product: Generic Platform OHCI controller [ 4.490870] usb usb3: Manufacturer: Linux 4.8.4-sunxi ohci_hcd [ 4.490876] usb usb3: SerialNumber: 1c14400.usb [ 4.491786] hub 3-0:1.0: USB hub found [ 4.491872] hub 3-0:1.0: 1 port detected [ 4.492840] ohci-platform 1c1c400.usb: Generic Platform OHCI controller [ 4.492887] ohci-platform 1c1c400.usb: new USB bus registered, assigned bus number 4 [ 4.493149] ohci-platform 1c1c400.usb: irq 35, io mem 0x01c1c400 [ 4.560840] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001 [ 4.560852] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 4.560859] usb usb4: Product: Generic Platform OHCI controller [ 4.560866] usb usb4: Manufacturer: Linux 4.8.4-sunxi ohci_hcd [ 4.560872] usb usb4: SerialNumber: 1c1c400.usb [ 4.561777] hub 4-0:1.0: USB hub found [ 4.561877] hub 4-0:1.0: 1 port detected [ 4.562907] usb_phy_generic.0.auto supply vcc not found, using dummy regulator [ 4.563516] musb-hdrc musb-hdrc.1.auto: MUSB HDRC host driver [ 4.563535] musb-hdrc musb-hdrc.1.auto: new USB bus registered, assigned bus number 5 [ 4.563991] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002 [ 4.564001] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 4.564008] usb usb5: Product: MUSB HDRC host driver [ 4.564014] usb usb5: Manufacturer: Linux 4.8.4-sunxi musb-hcd [ 4.564021] usb usb5: SerialNumber: musb-hdrc.1.auto [ 4.564923] hub 5-0:1.0: USB hub found [ 4.565008] hub 5-0:1.0: 1 port detected [ 4.597611] of_cfs_init [ 4.597743] of_cfs_init: OK [ 4.604736] vcc3v0: disabling [ 4.604754] vcc5v0: disabling [ 4.604778] ldo3: disabling [ 4.605188] ldo4: disabling [ 4.605512] ahci-5v: disabling [ 4.607467] Freeing unused kernel memory: 1024K (c0e00000 - c0f00000) [ 4.670155] systemd-udevd[173]: starting version 215 [ 4.736677] usb 1-1: new high-speed USB device number 2 using ehci-platform [ 4.776728] usb 2-1: new high-speed USB device number 2 using ehci-platform [ 4.930901] usb 1-1: New USB device found, idVendor=05e3, idProduct=0610 [ 4.930917] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0 [ 4.930924] usb 1-1: Product: USB2.0 Hub [ 4.930932] usb 1-1: Manufacturer: GenesysLogic [ 4.932784] hub 1-1:1.0: USB hub found [ 4.933529] hub 1-1:1.0: 4 ports detected [ 4.969777] usb 2-1: New USB device found, idVendor=0bda, idProduct=8176 [ 4.969794] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3 [ 4.969801] usb 2-1: Product: 802.11n WLAN Adapter [ 4.969809] usb 2-1: Manufacturer: Realtek [ 4.969815] usb 2-1: SerialNumber: 00e04c000001 [ 5.257108] usb 1-1.1: new low-speed USB device number 3 using ehci-platform [ 5.414710] usb 1-1.1: New USB device found, idVendor=0e8f, idProduct=0022 [ 5.414727] usb 1-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0 [ 5.414734] usb 1-1.1: Product: USB KB V11 [ 5.414742] usb 1-1.1: Manufacturer: GASIA [ 5.421227] input: GASIA USB KB V11 as /devices/platform/soc@01c00000/1c14000.usb/usb1/1-1/1-1.1/1-1.1:1.0/0003:0E8F:0022.0001/input/input1 [ 5.487182] hid-generic 0003:0E8F:0022.0001: input,hidraw0: USB HID v1.10 Keyboard [GASIA USB KB V11] on usb-1c14000.usb-1.1/input0 [ 5.495663] input: GASIA USB KB V11 as /devices/platform/soc@01c00000/1c14000.usb/usb1/1-1/1-1.1/1-1.1:1.1/0003:0E8F:0022.0002/input/input2 [ 5.557315] hid-generic 0003:0E8F:0022.0002: input,hidraw1: USB HID v1.10 Device [GASIA USB KB V11] on usb-1c14000.usb-1.1/input1 [ 7.367808] EXT4-fs (mmcblk0p1): mounted filesystem with writeback data mode. Opts: (null) [ 7.801258] systemd[1]: systemd 215 running in system mode. (+PAM +AUDIT +SELINUX +IMA +SYSVINIT +LIBCRYPTSETUP +GCRYPT +ACL +XZ -SECCOMP -APPARMOR) [ 7.801729] systemd[1]: Detected architecture 'arm'. [ 7.830813] systemd[1]: Set hostname to <cubieboard>. [ 8.288389] systemd[1]: Cannot add dependency job for unit display-manager.service, ignoring: Unit display-manager.service failed to load: No such file or directory. [ 8.291571] systemd[1]: Starting Forward Password Requests to Wall Directory Watch. [ 8.292109] systemd[1]: Started Forward Password Requests to Wall Directory Watch. [ 8.292207] systemd[1]: Expecting device dev-ttyS0.device... [ 8.292999] systemd[1]: Starting Remote File Systems (Pre). [ 8.293546] systemd[1]: Reached target Remote File Systems (Pre). [ 8.293674] systemd[1]: Starting Encrypted Volumes. [ 8.387287] random: crng init done [ 8.506928] fuse init (API version 7.25) [ 8.575940] Ethernet Channel Bonding Driver: v3.7.1 (April 27, 2011) [ 8.949265] systemd-udevd[263]: starting version 215 [ 9.707985] sun4i-ss 1c15000.crypto-engine: no reset control found [ 9.709662] sun4i-ss 1c15000.crypto-engine: Die ID 0 [ 9.857437] Registered IR keymap rc-empty [ 9.858027] input: sunxi-ir as /devices/platform/soc@01c00000/1c21800.ir/rc/rc0/input3 [ 9.858064] rc rc0: sunxi-ir as /devices/platform/soc@01c00000/1c21800.ir/rc/rc0 [ 9.893985] lirc_dev: IR Remote Control driver registered, major 244 [ 9.894449] sunxi-ir 1c21800.ir: initialized sunXi IR driver [ 9.912530] rc rc0: lirc_dev: driver ir-lirc-codec (sunxi-ir) registered at minor = 0 [ 9.912550] IR LIRC bridge handler initialized [ 9.940196] sun4i-codec 1c22c00.codec: Codec <-> 1c22c00.codec mapping ok [ 10.300537] rtl8192cu: Chip version 0x10 [ 10.514294] rtl8192cu: Board Type 0 [ 10.514742] rtl_usb: rx_max_size 15360, rx_urb_num 8, in_ep 1 [ 10.514879] rtl8192cu: Loading firmware rtlwifi/rtl8192cufw_TMSC.bin [ 10.515671] ieee80211 phy0: Selected rate control algorithm 'rtl_rc' [ 10.517462] usbcore: registered new interface driver rtl8192cu [ 10.538503] EXT4-fs (mmcblk0p1): re-mounted. Opts: commit=600,errors=remount-ro [ 10.993449] Adding 131068k swap on /var/swap. Priority:-1 extents:2 across:352252k SSFS [ 12.083441] systemd-journald[246]: Received request to flush runtime journal from PID 1 [ 12.948789] sun7i-dwmac 1c50000.ethernet: Failed to reset the dma [ 12.948803] stmmac_hw_setup: DMA engine initialization failed [ 12.948809] stmmac_open: Hw setup failed [ 75.988929] sun7i-dwmac 1c50000.ethernet: Failed to reset the dma [ 75.988948] stmmac_hw_setup: DMA engine initialization failed [ 75.988954] stmmac_open: Hw setup failed [ 80.044527] rtl8192cu: MAC auto ON okay! [ 80.094007] rtl8192cu: Tx queue select: 0x05 [ 80.620758] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready [ 86.518904] sun7i-dwmac 1c50000.ethernet: Failed to reset the dma [ 86.518919] stmmac_hw_setup: DMA engine initialization failed [ 86.518925] stmmac_open: Hw setup failed [ 97.639581] sun7i-dwmac 1c50000.ethernet: Failed to reset the dma [ 97.639600] stmmac_hw_setup: DMA engine initialization failed [ 97.639607] stmmac_open: Hw setup failed [ 104.114006] rtl8192cu: MAC auto ON okay! [ 104.148405] rtl8192cu: Tx queue select: 0x05 [ 104.615330] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready [ 105.319170] sun7i-dwmac 1c50000.ethernet: Failed to reset the dma [ 105.319191] stmmac_hw_setup: DMA engine initialization failed [ 105.319198] stmmac_open: Hw setup failed [ 105.599333] sun7i-dwmac 1c50000.ethernet: Failed to reset the dma [ 105.599352] stmmac_hw_setup: DMA engine initialization failed [ 105.599359] stmmac_open: Hw setup failed [ 106.387964] rtl8192cu: MAC auto ON okay! [ 106.422238] rtl8192cu: Tx queue select: 0x05 [ 106.911639] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready [ 107.423985] usb 1-1: clear tt 1 (0030) error -32 [ 107.726319] usb 1-1.1: reset low-speed USB device number 3 using ehci-platform [ 108.386302] usb 1-1.1: reset low-speed USB device number 3 using ehci-platform [ 117.796132] usb 1-1.4: new low-speed USB device number 4 using ehci-platform [ 117.951737] usb 1-1.4: New USB device found, idVendor=046d, idProduct=c00e [ 117.951762] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0 [ 117.951787] usb 1-1.4: Product: USB-PS/2 Optical Mouse [ 117.951799] usb 1-1.4: Manufacturer: Logitech [ 117.960400] input: Logitech USB-PS/2 Optical Mouse as /devices/platform/soc@01c00000/1c14000.usb/usb1/1-1/1-1.4/1-1.4:1.0/0003:046D:C00E.0003/input/input4 [ 117.961442] hid-generic 0003:046D:C00E.0003: input,hidraw2: USB HID v1.10 Mouse [Logitech USB-PS/2 Optical Mouse] on usb-1c14000.usb-1.4/input0 [ 118.593006] usb 1-1: clear tt 4 (0040) error -32 [ 118.830886] usb 1-1.4: USB disconnect, device number 4 [ 119.186123] usb 1-1.4: new low-speed USB device number 5 using ehci-platform [ 119.341728] usb 1-1.4: New USB device found, idVendor=046d, idProduct=c00e [ 119.341753] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0 [ 119.341764] usb 1-1.4: Product: USB-PS/2 Optical Mouse [ 119.341776] usb 1-1.4: Manufacturer: Logitech [ 119.353048] input: Logitech USB-PS/2 Optical Mouse as /devices/platform/soc@01c00000/1c14000.usb/usb1/1-1/1-1.4/1-1.4:1.0/0003:046D:C00E.0004/input/input5 [ 119.354754] hid-generic 0003:046D:C00E.0004: input,hidraw2: USB HID v1.10 Mouse [Logitech USB-PS/2 Optical Mouse] on usb-1c14000.usb-1.4/input0 [ 145.662827] rtl8192cu: MAC auto ON okay! [ 145.696886] rtl8192cu: Tx queue select: 0x05 [ 146.142891] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready [ 146.829158] sun7i-dwmac 1c50000.ethernet: Failed to reset the dma [ 146.829177] stmmac_hw_setup: DMA engine initialization failed [ 146.829185] stmmac_open: Hw setup failed [ 147.118690] sun7i-dwmac 1c50000.ethernet: Failed to reset the dma [ 147.118710] stmmac_hw_setup: DMA engine initialization failed [ 147.118717] stmmac_open: Hw setup failed [ 147.418267] usb 1-1: clear tt 4 (0050) error -32 [ 147.665261] usb 1-1.4: USB disconnect, device number 5 [ 147.995881] usb 1-1.4: new low-speed USB device number 6 using ehci-platform [ 148.152149] usb 1-1.4: New USB device found, idVendor=046d, idProduct=c00e [ 148.152176] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0 [ 148.152187] usb 1-1.4: Product: USB-PS/2 Optical Mouse [ 148.152199] usb 1-1.4: Manufacturer: Logitech [ 148.160889] input: Logitech USB-PS/2 Optical Mouse as /devices/platform/soc@01c00000/1c14000.usb/usb1/1-1/1-1.4/1-1.4:1.0/0003:046D:C00E.0005/input/input6 [ 148.162104] hid-generic 0003:046D:C00E.0005: input,hidraw2: USB HID v1.10 Mouse [Logitech USB-PS/2 Optical Mouse] on usb-1c14000.usb-1.4/input0 [ 150.008701] sun7i-dwmac 1c50000.ethernet: Failed to reset the dma [ 150.008719] stmmac_hw_setup: DMA engine initialization failed [ 150.008727] stmmac_open: Hw setup failed [ 158.278577] sun7i-dwmac 1c50000.ethernet: Failed to reset the dma [ 158.278595] stmmac_hw_setup: DMA engine initialization failed [ 158.278602] stmmac_open: Hw setup failed [ 163.098731] sun7i-dwmac 1c50000.ethernet: Failed to reset the dma [ 163.098750] stmmac_hw_setup: DMA engine initialization failed [ 163.098758] stmmac_open: Hw setup failed [ 171.368634] sun7i-dwmac 1c50000.ethernet: Failed to reset the dma [ 171.368654] stmmac_hw_setup: DMA engine initialization failed [ 171.368661] stmmac_open: Hw setup failed [ 188.818964] rtl8192cu: MAC auto ON okay! [ 188.853136] rtl8192cu: Tx queue select: 0x05 [ 189.302571] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready [ 204.388128] sun7i-dwmac 1c50000.ethernet: Failed to reset the dma [ 204.388148] stmmac_hw_setup: DMA engine initialization failed [ 204.388155] stmmac_open: Hw setup failed [ 212.657985] sun7i-dwmac 1c50000.ethernet: Failed to reset the dma [ 212.658003] stmmac_hw_setup: DMA engine initialization failed [ 212.658011] stmmac_open: Hw setup failed [ 218.989729] rtl8192cu: MAC auto ON okay! [ 219.027295] rtl8192cu: Tx queue select: 0x05 [ 219.483635] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready [ 220.147897] sun7i-dwmac 1c50000.ethernet: Failed to reset the dma [ 220.147917] stmmac_hw_setup: DMA engine initialization failed [ 220.147925] stmmac_open: Hw setup failed [ 220.438332] sun7i-dwmac 1c50000.ethernet: Failed to reset the dma [ 220.438351] stmmac_hw_setup: DMA engine initialization failed [ 220.438360] stmmac_open: Hw setup failed [ 221.937860] sun7i-dwmac 1c50000.ethernet: Failed to reset the dma [ 221.937882] stmmac_hw_setup: DMA engine initialization failed [ 221.937889] stmmac_open: Hw setup failed [ 222.396959] rtl8192cu: MAC auto ON okay! [ 222.431282] rtl8192cu: Tx queue select: 0x05 [ 222.898398] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready [ 226.123113] usb 1-1: clear tt 4 (0060) error -32 [ 226.359516] usb 1-1.4: USB disconnect, device number 6 [ 226.570267] wlan0: authenticate with f0:b4:29:59:45:6f [ 226.596375] wlan0: send auth to f0:b4:29:59:45:6f (try 1/3) [ 226.674011] wlan0: authenticated [ 226.675756] wlan0: associate with f0:b4:29:59:45:6f (try 1/3) [ 226.695029] usb 1-1.4: new low-speed USB device number 7 using ehci-platform [ 226.706755] wlan0: RX AssocResp from f0:b4:29:59:45:6f (capab=0xc31 status=0 aid=2) [ 226.709448] wlan0: associated [ 226.709708] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready [ 226.850733] usb 1-1.4: New USB device found, idVendor=046d, idProduct=c00e [ 226.850757] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0 [ 226.850782] usb 1-1.4: Product: USB-PS/2 Optical Mouse [ 226.850794] usb 1-1.4: Manufacturer: Logitech [ 226.863345] input: Logitech USB-PS/2 Optical Mouse as /devices/platform/soc@01c00000/1c14000.usb/usb1/1-1/1-1.4/1-1.4:1.0/0003:046D:C00E.0006/input/input7 [ 226.864510] hid-generic 0003:046D:C00E.0006: input,hidraw2: USB HID v1.10 Mouse [Logitech USB-PS/2 Optical Mouse] on usb-1c14000.usb-1.4/input0 [ 227.925076] usb 1-1: clear tt 4 (0070) error -32 [ 228.164294] usb 1-1.4: USB disconnect, device number 7 [ 228.495008] usb 1-1.4: new low-speed USB device number 8 using ehci-platform [ 228.660729] usb 1-1.4: New USB device found, idVendor=046d, idProduct=c00e [ 228.660753] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0 [ 228.660764] usb 1-1.4: Product: USB-PS/2 Optical Mouse [ 228.660776] usb 1-1.4: Manufacturer: Logitech [ 228.670173] input: Logitech USB-PS/2 Optical Mouse as /devices/platform/soc@01c00000/1c14000.usb/usb1/1-1/1-1.4/1-1.4:1.0/0003:046D:C00E.0007/input/input8 [ 228.671185] hid-generic 0003:046D:C00E.0007: input,hidraw2: USB HID v1.10 Mouse [Logitech USB-PS/2 Optical Mouse] on usb-1c14000.usb-1.4/input0 [ 229.749246] usb 1-1: clear tt 4 (0080) error -32 [ 229.998379] usb 1-1.4: USB disconnect, device number 8 [ 230.218009] sun7i-dwmac 1c50000.ethernet: Failed to reset the dma [ 230.218029] stmmac_hw_setup: DMA engine initialization failed [ 230.218036] stmmac_open: Hw setup failed [ 230.334922] usb 1-1.4: new low-speed USB device number 9 using ehci-platform [ 230.490604] usb 1-1.4: New USB device found, idVendor=046d, idProduct=c00e [ 230.490630] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0 [ 230.490641] usb 1-1.4: Product: USB-PS/2 Optical Mouse [ 230.490653] usb 1-1.4: Manufacturer: Logitech [ 230.503406] input: Logitech USB-PS/2 Optical Mouse as /devices/platform/soc@01c00000/1c14000.usb/usb1/1-1/1-1.4/1-1.4:1.0/0003:046D:C00E.0008/input/input9 [ 230.504396] hid-generic 0003:046D:C00E.0008: input,hidraw2: USB HID v1.10 Mouse [Logitech USB-PS/2 Optical Mouse] on usb-1c14000.usb-1.4/input0 [ 253.309619] usb 1-1: clear tt 4 (0090) error -32 [ 253.549519] usb 1-1.4: USB disconnect, device number 9 https://drive.google.com/open?id=0B-6BIQC_H2vlNlNfMjk0OExMREk
vba Posted November 2, 2016 Posted November 2, 2016 I got a smilair problem on Banana Pi Pro. But i haven't found a solution yet. (An older kernel maybe the quick fix rigth now)
Jimbo555 Posted November 2, 2016 Author Posted November 2, 2016 I got a smilair problem on Banana Pi Pro. But i haven't found a solution yet. (An older kernel maybe the quick fix rigth now) I think this is due to the bootstrap script. Disable standby Internet connection and the system will start without problems Try to install an older version, and then if you want to upgrade to the latest
vba Posted November 3, 2016 Posted November 3, 2016 I think this is due to the bootstrap script. Disable standby Internet connection and the system will start without problems Try to install an older version, and then if you want to upgrade to the latest Hello Jimbo555. Can you provide me the steps to disable standby internet connection? Thanks
Jimbo555 Posted November 3, 2016 Author Posted November 3, 2016 Hello Jimbo555. Can you provide me the steps to disable standby internet connection? Thanks Just burn the image Armbian_5.10_Cubieboard2_Debian_jessie_4.5.2_desktop And try to boot
