jumbo125 Posted April 27, 2023 Share Posted April 27, 2023 Hello I use armbian on my odroidc2 on the devic is lamp, for a mysql and php server. Now i tried to install composer. The installation works great, but i can't use any scripts from vendor folder. The directory of my php file: /var/www/html/terminal/includes/helpers/my_php_file.php the code in my php file require_once(__DIR__ . '/vendor/autoload.php'); The code means the vendor directory has this path: /var/www/html/terminal/includes/helpers/vendor/autoload.php But thats not correct. I searched and found the correct path of composer it's: /home/user/vendor/ So i tried to make a folder-shortcut in my www/html/ folder, but i can't use it because permission denied. Next idea: i fix the code in my php file include '../../../../../../home/odroid/vendor/autoload.php'; now it would be found, but i get the same error: Warning: include(../../../../../../home/odroid/vendor/autoload.php): Failed to open stream: Permission denied in /var/www/html/terminal/includes/helpers/backup_DB.php on line 26 what's the correct way to youe composer with autoload.php and something more? 0 Quote Link to comment Share on other sites More sharing options...
