Just tried Armbian 23.5 Bookworm, cli & minimal.   Both report the same in the console.  Board works just fine with official img from www.friendlyelec.com
Here is the terminal output.
U-Boot SPL 2022.07-armbian (Apr 04 2023 - 04:26:17 +0000)
DRAM: 512 MiB
Trying to boot from MMC1
U-Boot 2022.07-armbian (Apr 04 2023 - 04:26:17 +0000) Allwinner Technology
CPU:   Allwinner H3 (SUN8I 1680)
Model: FriendlyARM NanoPi NEO
DRAM:  512 MiB
Core:  60 devices, 17 uclasses, devicetree: separate
WDT:   Not starting watchdog@1c20ca0
MMC:   mmc@1c0f000: 0
Loading Environment from FAT... Unable to use mmc 0:1...
In:    serial
Out:   serial
Err:   serial
Net:   phy interface1
eth0: ethernet@1c30000
starting USB...
Bus usb@1c1a000: USB EHCI 1.00
Bus usb@1c1a400: USB OHCI 1.0
Bus usb@1c1d000: USB EHCI 1.00
Bus usb@1c1d400: USB OHCI 1.0
scanning bus usb@1c1a000 for devices... 1 USB Device(s) found
scanning bus usb@1c1a400 for devices... 1 USB Device(s) found
scanning bus usb@1c1d000 for devices... 2 USB Device(s) found
scanning bus usb@1c1d400 for devices... 1 USB Device(s) found
Autoboot in 1 seconds, press <Space> to stop
switch to partitions #0, OK
mmc0 is current device
Scanning mmc 0:1...
4121 bytes read in 2 ms (2 MiB/s)
U-boot loaded from SD
Boot script loaded from mmc
234 bytes read in 2 ms (114.3 KiB/s)
10645606 bytes read in 442 ms (23 MiB/s)
8868040 bytes read in 369 ms (22.9 MiB/s)
Failed to load '/boot/dtb/allwinner/sun8i-h3-nanopi-duo2.dtb'
libfdt fdt_check_header(): FDT_ERR_BADMAGIC
No FDT memory address configured. Please configure
the FDT address via "fdt addr <address>" command.
Aborting!
504 bytes read in 4 ms (123 KiB/s)
Applying kernel provided DT overlay sun8i-h3-usbhost0.dtbo
Aborting!
Applying kernel provided DT overlay sun8i-h3-usbhost2.dtbo
Aborting!
504 bytes read in 5 ms (97.7 KiB/s)
Applying kernel provided DT overlay sun8i-h3-usbhost3.dtbo
Aborting!
Error applying DT overlays, restoring original DT
Kernel image @ 0x42000000 [ 0x000000 - 0x8750c8 ]
## Loading init Ramdisk from Legacy Image at 43400000 ...
   Image Name:   uInitrd
   Image Type:   ARM Linux RAMDisk Image (gzip compressed)
   Data Size:    10645542 Bytes = 10.2 MiB
   Load Address: 00000000
   Entry Point:  00000000
   Verifying Checksum ... OK
ERROR: Did not find a cmdline Flattened Device Tree
Could not find a valid device tree
SCRIPT FAILED: continuing...
No EFI system partition
BootOrder not defined
EFI boot manager: Cannot load any image
Device 0: unknown device
ethernet@1c30000 Waiting for PHY auto negotiation to complete. done
BOOTP broadcast 1
BOOTP broadcast 2
BOOTP broadcast 3
BOOTP broadcast 4
DHCP client bound to address 192.168.0.11 (3020 ms)
*** Warning: no boot file name; using 'C0A8000B.img'
Using ethernet@1c30000 device
TFTP from server 192.168.0.1; our IP address is 192.168.0.11
Filename 'C0A8000B.img'.
Load address: 0x42000000
Loading: T T T T
