DeterminedOpier Posted May 16, 2023 Posted May 16, 2023 Hi gang. I am having a consistent problem changing the board over boot from the SD with the system on any kind of USB attached drive. The drive I want to put it on is a 1t ssb, which otherwise formats fine, over and over again, burns images on it fine (though rpi doesn't like how much power it grabs). But I duplicated the problem with a formatted SD card in a reader in the USB port as well. The same error message appeared. Now I have to say that I have read this post here: to see if there was anything unique to the H3 to accomplish this, but Igor said there to just follow the simple directions at Getting Started, which though dated, still work close to the same. This just seems busted to me. I don't know. I am attaching the final screen I am getting, and tried to >/tmp/boot.txt with the journal command it says to do, but though I saw the file in the /tmp after I did it on the board, it was neither in the /tmp of the original file system or the copied one. Thanks as always. 0 Quote
DeterminedOpier Posted May 31, 2023 Author Posted May 31, 2023 This is still open btw. Now my HC4 won't work booting from the flash, and yes I had erased the pettiboot stuff. I don't know i this stuff is just not ready for prime time, which is fine. 0 Quote
