NaK Posted May 28, 2023 Share Posted May 28, 2023 For the Rock PI S, what is the recommended gpio library? I tried using Radxa libmraa but encountered the following errors (using bullseye-stable): $ sudo apt-get install -y libmraa ... The following packages have unmet dependencies: libmraa : Depends: libjson-c3 but it is not installable Depends: python but it is not installable Depends: python2.7 but it is not installable Depends: libpython2.7 but it is not installable Depends: python3.7 but it is not installable Depends: libpython3.7 but it is not installable E: Unable to correct problems, you have held broken packages. 0 Quote Link to comment Share on other sites More sharing options...
NaK Posted May 29, 2023 Author Share Posted May 29, 2023 Compiling libmraa from source worked, per the instructions here. 1 Quote Link to comment Share on other sites More sharing options...
NaK Posted June 5, 2023 Author Share Posted June 5, 2023 (edited) Note: I needed to include swig (in addition to swig 4.0) to compile. Edited June 5, 2023 by NaK 0 Quote Link to comment Share on other sites More sharing options...
