Orange Pi+ 2 not booting up or bootloops !
yo8aiv
http://paste.armbian.com/icedujiguw.yaml
Hello everyone,
trying to give  new life  to this old  Orange Pi+ 2. Here is described what hapens when i try to boot up latest image. Can anyone help. Thanks in advance.
Armbian 23.8 Bookworm Kernel 6.2.y, Size: 421Mb, Release date: Jun 3, 2023
SBC gets stuck after the request Sense .. and doesnt booy up, if i plug a device in usb ports, it bootloops .. see below
using same sd-card and a diffrent image file works with no issues .
hardware grounded out pin 9 of the SD card slot (checked with multimeter and works)
U-Boot SPL 2022.07-armbian (Jun 03 2023 - 19:37:25 +0000)
DRAM: 2048 MiB
Trying to boot from MMC1
U-Boot 2022.07-armbian (Jun 03 2023 - 19:37:25 +0000) Allwinner Technology
CPU:   Allwinner H3 (SUN8I 1680)
Model: Xunlong Orange Pi Plus / Plus 2
DRAM:  2 GiB
Core:  65 devices, 18 uclasses, devicetree: separate
WDT:   Not starting watchdog@1c20ca0
MMC:   mmc@1c0f000: 0, mmc@1c10000: 2, mmc@1c11000: 1
Loading Environment from FAT... Unable to use mmc 0:1...
In:    serial@1c28000
Out:   serial@1c28000
Err:   serial@1c28000
Net:   phy interface9
eth0: ethernet@1c30000
starting USB...
Bus usb@1c1b000: USB EHCI 1.00
Bus usb@1c1d000: USB EHCI 1.00
scanning bus usb@1c1b000 for devices... EHCI timed out on TD - token=0x80008c80
unable to get device descriptor (error=-1)
2 USB Device(s) found
scanning bus usb@1c1d000 for devices... Device NOT ready
   Request Sense returned 02 3A 00
DRAM: 2048 MiB
DRAM:  2 GiB
In:    serial@1c28000
Out:   serial@1c28000
Err:   serial@1c28000
Net:   phy interface9
starting USB...
scanning bus usb@1c1b000 for devices... Device NOT ready
undefined instruction
pc : [<bbf93980>]          lr : [<bffa3391>]
reloc pc : [<4600b980>]    lr : [<4a01b391>]
sp : bbf5e848  ip : 0000001c     fp : bffde94a
r10: bffe5c00  r9 : bbf67ec0     r8 : 00000000
r7 : 00000000  r6 : bbf93b18     r5 : a0000000  r4 : bbf93b80
r3 : bbf93980  r2 : 00000000     r1 : 00000000  r0 : bbf93b80
Flags: NzCv  IRQs off  FIQs off  Mode SVC_32
Code: bbf68cc8 00000000 00000000 00000000 (ffffffff)
Resetting CPU ...
resetting ...
DRAM: 2048 MiB
Edited by yo8aiv
adding details
