RSS Bot Posted June 19, 2023 Share Posted June 19, 2023 Description Bump 32-bit kernel to 6.3.8. I didn't bumped it for 64-bit sunxi devices as drv-rgb-add-ws2812.patch introduced in #5267 makes use of of_get_named_gpio_flags function which is removed in 6.3. As I don't have a Bigtreetech cb1, I am not comfortable modifying code to fix this patch. The kernel module added by drv-rgb-add-ws2812.patch is not enabled for 32-bit devices and hence it doesn't cause compilation issues on 32-bit sunxi kernel. Excluding drv-rgb-add-ws2812.patch, I have updated any patch that was broken, and have disabled patches where changes were present upstream. Also disabled same rockchip related patches that I disabled in #5326 How Has This Been Tested? [X] Created an image and booted on Nanopi duo2 Checklist: [ ] My code follows the style guidelines of this project [ ] I have performed a self-review of my own code [ ] I have commented my code, particularly in hard-to-understand areas [ ] I have made corresponding changes to the documentation [X] My changes generate no new warnings [ ] Any dependent changes have been merged and published in downstream modules View the full article Link to comment Share on other sites More sharing options...
