8 hours ago, mvpwar said:
I found the 0x0000A000 is the dtb partition start address of Android image , I want to know your GPT partition table of emmc
You find it!
Nice!
Uboot for 8gb devices are newer
So the loadder use address instead of name
Just change the GPT address on parameter.txt
I don't have this device to test, but it looks a great start
Edited by hotnikq
4 hours ago, hotnikq said:
The GPT parameters you will find on
Parameter.Txt
FIRMWARE_VER: 12.0
MACHINE_MODEL: H96_Max_V56
MACHINE_ID: 007
MANUFACTURER: rockchip
MAGIC: 0x5041524B
ATAG: 0x00200800
MACHINE: rk3566_box
CHECK_MASK: 0x80
PWR_HLD: 0,0,A,0,1
TYPE: EXT4
CMDLINE: console=ttyFIQ0 androidboot.console=ttyFIQ0 root=UUID=c79ae8c4-0a9a-479b-b57f-ed7575bf5017 rw rootfstype=ext4 no_console_suspend consoleblank=0 fsck.fix=yes fsck.repair=yes net.ifnames=0 splash plymouth.ignore-serial-consoles mtdparts=rk29xxnand:0x00002000@0x00004000(security),0x00002000@0x00006000(uboot),0x00002000@0x00008000(trust),-@0x0010800(root:grow)
uuid:root=c79ae8c4-0a9a-479b-b57f-ed7575bf5017
this parameter.txt is not useful when the TYPE is EXT4,  Only parameter.txt with GPT type is available, like the parameter.txt of unpacked Android image
FIRMWARE_VER: 11.0
MACHINE_MODEL: H96_Max_RK3566
MACHINE_ID: 007
MAGIC: 0x5041524B
ATAG: 0x00200800
MACHINE: rk356x_box
CHECK_MASK: 0x80
PWR_HLD: 0,0,A,0,1
TYPE: GPT
CMDLINE:mtdparts=rk29xxnand:0x00002000@0x00004000(uboot),0x00002000@0x00006000(trust),0x00002000@0x00008000(misc),0x00002000@0x0000a000(dtbo),0x00000800@0x0000c000(vbmeta),0x00014000@0x0000c800(boot),0x00002000@0x00020800(security),0x00030000@0x00022800(recovery),0x000c0000@0x00052800(backup),0x000d7fff@0x00112800(cache),0x00008000@0x001ea7ff(metadata),0x00000400@0x001f27ff(frp),0x00000800@0x001f2bff(baseparameter),0x00008000@0x001f33ff(logo),0x006b8000@0x001fb3ff(super),-@0x008b33ff(userdata:grow)
 I want to know your GPT partition table which outputed by clicking the "Dev Partition" in the RKDevTool
If the box inconvenient to shut down, can you execute the “blkid” command in the shell  @hotnikq
the result of my box by clicking the "Dev Partition"  as below
Edited by mvpwar
Create an Parameter.txt File like this
FIRMWARE_VER: 12.0
MACHINE_ID: 007
MAGIC: 0x5041524B
ATAG: 0x00200800
MACHINE: rk3566_box
CHECK_MASK: 0x80
PWR_HLD: 0,0,A,0,1
TYPE: EXT4
CMDLINE: console=ttyFIQ0 androidboot.console=ttyFIQ0 root=UUID=c79ae8c4-0a9a-479b-b57f-ed7575bf5017 rw rootfstype=ext4 no_console_suspend consoleblank=0 fsck.fix=yes fsck.repair=yes net.ifnames=0 splash plymouth.ignore-serial-consoles mtdparts=rk29xxnand:0x00002000@0x00004000(uboot),0x00002000@0x00006000(trust),0x00002000@0x00008000(misc),0x00002000@0x0000a000(dtbo),0x00000800@0x0000c000(vbmeta),-@0x0000d000(root:grow)
Extract from your android image
uboot.img
trust.img
misc.img
dtbo.img
vbmeta.img
and the "root,img" file you pickup from tutorial root image from this topic.
put it all inside image folder on rockdev
on rockdev folder edit the file package-file
# NAME		Relative path
#HWDEF		HWDEF
package-file	package-file
bootloader	Image/MiniLoaderAll.bin
parameter	Image/parameter.txt
trust		Image/dtbo.img
uboot		Image/uboot.img
security		Image/parameter.txt
#resource	Image/resource.img
#kernel		Image/kernel.img
root		Image/root.img
#recovery	Image/recovery.img
#rootfs		Image/rootfs.img
#oem		Image/oem.img
#userdata	Image/userdata.img
#backup		RESERVED
#update-script	update-script
#recover-script	recover-script
@mvpwar
This is the 4gb/32gb device
Edited by hotnikq
thanks a lot ! @hotnikq
Very important infomation for me, I will try your method later
is your 4G/32G box only using the emmc without sd card?
Edited by mvpwar
First I add SD card to test the dtb files faster
Then I create the internal flash 2 step
Now I just flash the MMC when I need to clean install
No SD SD card since v0.7 firmware
remembering that you should change only the update.img file that initializes the device
The root.img contains dtb file that works on both 4gb and 8gb devices
Edited by hotnikq
the problem is "Failed to mount ext2 filesystem" or Could not find the partition with the kernel and dtb file @hotnikq
BTW, your old ubuntu firmware works, and then I flashed the armbian v0.7 root.img to rootfs partition, armbian works but the kernel and dtb can not be change since it use boot.img and empty /boot dir of root.img
Edited by mvpwar
package-file
#HWDEF		HWDEF
root		Image/root.img
parameter.txt
FIRMWARE_VER: 11.0
MACHINE_ID: 007
MAGIC: 0x5041524B
ATAG: 0x00200800
MACHINE: rk356x_box
CHECK_MASK: 0x80
PWR_HLD: 0,0,A,0,1
TYPE: EXT4
CMDLINE: console=ttyFIQ0 androidboot.console=ttyFIQ0 root=UUID=614e0000-0000-4b53-8000-1d28000054a9 rw rootfstype=ext4 no_console_suspend consoleblank=0 fsck.fix=yes fsck.repair=yes net.ifnames=0 splash plymouth.ignore-serial-consoles mtdparts=rk29xxnand:0x00002000@0x00004000(security),0x00002000@0x00006000(uboot),0x00002000@0x00008000(trust),-@0x0000a000(root:grow)
uuid:root=614e0000-0000-4b53-8000-1d28000054a9
the root.img is Debian_23.08.0-H96MAX_RK3566_bookworm_ROOT_edge_6.2.16_xfce_desktop.img, also try the other root.img, the same result ...
start to make update.img...
Android Firmware Package Tool v1.66
------ PACKAGE ------
Add file: ./package-file
Add file: ./package-file done,offset=0x800,size=0xe1,userspace=0x1
Add file: ./Image/MiniLoaderAll.bin
Add file: ./Image/MiniLoaderAll.bin done,offset=0x1000,size=0x6a9c0,userspace=0xd6
Add file: ./Image/parameter.txt
Add file: ./Image/parameter.txt done,offset=0x6c000,size=0x269,userspace=0x1
Add file: ./Image/dtbo.img
Add file: ./Image/dtbo.img done,offset=0x6c800,size=0x26f,userspace=0x1
Add file: ./Image/uboot.img
Add file: ./Image/uboot.img done,offset=0x6d000,size=0x400000,userspace=0x800
Add file: ./Image/parameter.txt done,offset=0x46d000,size=0x25d,userspace=0x1
Add file: ./Image/root.img
Add file: ./Image/root.img done,offset=0x46d800,size=0x189ff6600,userspace=0x313fed
Add CRC...
Make firmware OK!
------ OK ------
********RKImageMaker ver 1.66********
Generating new image, please wait...
Writing head info...
Writing boot file...
Writing firmware...
Generating MD5 data...
MD5 data generated successfully!
New image generated successfully!
Making ./Image/update.img OK.
what the hell...
Edited by mvpwar
2 hours ago, mvpwar said:
what the hell...
Welcome to Linux
My god, you have that old image?
It works on 8gb devices?
Please Share it here with Google drive
I have deleted it
@Kenneth Hidalgo need your image to 8gb devices
Edited by hotnikq
This is a problem?
It's running kernel 6.2? Or the old kernel 4.2?
Edited by hotnikq
This is a problem?
your Ubuntu firmware works, but it's memory is only 4g though the 8g box, flash the armbian root.img to rootfs partition, armbian works, but the kernel is also 4.x , not 6.2 @hotnikq
maybe i upgrade debian 10.10 firmware and then flash the armbian root.img, my box can run the armbian , 8g ram, but the docker need kernel6.2, the kernel version of this debian firmware is 4.19.193
Edited by mvpwar
4.2, I don't know how to change the dtb and kernel , the /boot is empty , maybe the boot.img include kernel and dtb , but i can't unpack the boot.img using bootimg.exe and unpack_bootimg.py @hotnikq
ah it's to prevent Kernel panic on 4.19
it's my old kernel 😁
we are still at the ground point in this project for 8gb device......
waiting for your patch
i will delete my 8gb update images since your test got an error on uboot
I'll try again a desperate adaptation
Edited by hotnikq
actually the security partition of your box had been flashed the parameter.txt ?
and the dtb.img include the root partition uuid of bootargs?
Result:
update.img V4
execute step 1 with V4 update.img
execute step 2 with root.img (from tutorial)
set Address on 0x0000A000
set Name on root
update.img V5
execute step 1 with V5 update.img
set Address will be different value "0x00xxxx??????",
you will need to seach for partition named root
Please share this value if this image works
For update.img V5 i used a different pattern for Linux Pack Firmware
Edited by hotnikq
just to bloat the file inside, it works on my 4gb device
absolutly NOT, it's basically the same original android img file
4 hours ago, Kenneth Hidalgo said:
great, I'm desperate for a working OS on h96 max v56
You can also test it. I suspect that some steps may have been taken incorrectly,  I'm a bit busy for other things now @Kenneth Hidalgo
BTW, do you know the origin of  debian 10 linaro firmware ? link?
Edited by mvpwar
5 hours ago, hotnikq said:
Please test the V5 and V4 Before another different approach
the v4,v5 update.img can't not be read by RKDevTool @hotnikq
I try your rockdev of 8G_Linux_Pack_Firmware.zip , mkupdate.sh can genarate the update.img which can be loaded by RKDevTool,  so the 8G_Linux_Pack_Firmware.zip is correct.  are you using the same 8G_Linux_Pack_Firmware.zip for making image?
the command "./rkImageMaker -unpack update.img output " also return the error
Unpacking image, please wait...
Error:Check update.img failed!
Edited by mvpwar
6 minutes ago, hotnikq said:
Did it works?
I tried, the rockdev works, but your firmwares get corrupted , you can  check it at your pc
Generating files again....
Result
Update.img V4
set Name on root
Update.img V5
Edited by hotnikq
Test Result
v4:  failed...
U-Boot 2017.09-g32ed8ff-210328-dirty #pc (Apr 21 2021 - 20:51:20 +0800)
Model: Rockchip RK3568 Evaluation Board
PreSerial: 2, raw, 0xfe660000
DRAM:  7.7 GiB
Sysmem: init
Relocation Offset: ed39f000, fdt: eb9f8e18
Using default environment
Hotkey: ctrl+`
dwmmc@fe2b0000: 1, dwmmc@fe2c0000: 2, sdhci@fe310000: 0
Bootdev(atags): mmc 0
MMC0: HS200, 200Mhz
PartType: EFI
No misc partition
boot mode: None
FIT: No boot partition
No resource partition
Failed to load DTB
Failed to get kernel dtb, ret=-19
io-domain: OK
rockchip_set_serialno: could not find efuse/otp device
CLK: (sync kernel. arm: enter 816000 KHz, init 816000 KHz, kernel 0N/A)
  apll 816000 KHz
  dpll 390000 KHz
  gpll 1188000 KHz
  cpll 1000000 KHz
  npll 24000 KHz
  vpll 24000 KHz
  hpll 24000 KHz
  ppll 100000 KHz
  armclk 816000 KHz
  aclk_bus 150000 KHz
  pclk_bus 50000 KHz
  aclk_top_high 300000 KHz
  aclk_top_low 200000 KHz
  hclk_top 150000 KHz
  pclk_top 50000 KHz
  aclk_perimid 300000 KHz
  hclk_perimid 150000 KHz
  pclk_pmu 50000 KHz
Net:   No ethernet found.
Hit key to stop autoboot('CTRL+C'):  0
## Booting FIT Image FIT: No boot partition
FIT: No FIT image
Could not find misc partition
ANDROID: reboot reason: "(none)"
optee api revision: 2.0
TEEC: Reset area[0] info...
TEEC: Reset area[1] info...
Not AVB images, AVB skip
android_image_load_by_partname: Can't find part: boot
Android image load failed
Android boot failed, error -1.
MMC error: The cmd index is 1, ret is -110
Card did not respond to voltage select!
mmc_init: -95, time 10
switch to partitions #0, OK
mmc0(part 0) is current device
Failed to mount ext2 filesystem...
starting USB...
Bus dwc3@fcc00000: usb maximum-speed not found
Register 2000140 NbrPorts 2
Starting the controller
USB XHCI 1.10
Bus dwc3@fd000000: usb maximum-speed not found
USB XHCI 1.10
scanning bus dwc3@fcc00000 for devices... 1 USB Device(s) found
scanning bus dwc3@fd000000 for devices... 1 USB Device(s) found
Device 0: unknown device
No ethernet found.
missing environment variable: bootfile
Retrieving file: pxelinux.cfg/00000000
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
Retrieving file: pxelinux.cfg/default-arm-rockchip
No ethernet found.
No ethernet found.
No ethernet found.
Config file not found
No ethernet found.
No ethernet found.
v5:  failed ... the same problem @hotnikq
Edited by mvpwar
Just now, hotnikq said:
what is the address that you flash the root.img partition on tutorial part 2?
 the same 0x0000A000 ,since the v5 update.img would not change the GPT partition
when i unpace the v5 update.img , the TYPE of parameter.txt is EXT4, which would cause the partition table  keep the same @hotnikq
please get the DEV Partition from image v5 from the flashed device!!!!
i have changed it 😨
Edited by hotnikq
