3 minutes ago, hotnikq said:
please get the DEV Partition from image v5 from the flashed device!!!!
i have changed it
the partition table now as below, I had change the root partition to 0x00010800 refer to unpacked v4 image @hotnikq
Edited by mvpwar
OK the V5 image address is 0x00010800
you will need to flash the root.img in this address
please change it on the table
Edited by hotnikq
1 minute ago, hotnikq said:
LOL! did you fix it?
I'm at work now, can you recompile and test?
NO, the kernel can not be loaded, though I change the partition ,the same result
Not useful, I had tried many times @hotnikq
I asked the seller that the device (h96 max v56 4gb/32gb) had some version of Linux and he sent me that useless image, I made many changes to make it work but I still need to fix the size of the Root partition (6gb)
the root partition enlarge is very easy,  just enlarge the rootfs partition (change the parameter.txt, like root:grow), and resize2fs root block @Kenneth Hidalgo
1 hour ago, hotnikq said:
Balena etcher
when I selected the v5 update.img , the Balena etcher alert the image has no partition table , and I still flashed to the U stick, and boot fail thought the u-boot foud the usb device
@hotnikq debug message as below
U-Boot 2017.09-g32ed8ff-210328-dirty #pc (Apr 21 2021 - 20:51:20 +0800)
Model: Rockchip RK3568 Evaluation Board
PreSerial: 2, raw, 0xfe660000
DRAM:  7.7 GiB
Sysmem: init
Relocation Offset: ed39f000, fdt: eb9f8e18
Using default environment
Hotkey: ctrl+`
dwmmc@fe2b0000: 1, dwmmc@fe2c0000: 2, sdhci@fe310000: 0
Bootdev(atags): mmc 0
MMC0: HS200, 200Mhz
PartType: EFI
boot mode: None
FIT: No fdt blob
No resource partition
Failed to load DTB
Failed to get kernel dtb, ret=-19
io-domain: OK
rockchip_set_serialno: could not find efuse/otp device
CLK: (sync kernel. arm: enter 816000 KHz, init 816000 KHz, kernel 0N/A)
  apll 816000 KHz
  dpll 390000 KHz
  gpll 1188000 KHz
  cpll 1000000 KHz
  npll 24000 KHz
  vpll 24000 KHz
  hpll 24000 KHz
  ppll 100000 KHz
  armclk 816000 KHz
  aclk_bus 150000 KHz
  pclk_bus 50000 KHz
  aclk_top_high 300000 KHz
  aclk_top_low 200000 KHz
  hclk_top 150000 KHz
  pclk_top 50000 KHz
  aclk_perimid 300000 KHz
  hclk_perimid 150000 KHz
  pclk_pmu 50000 KHz
Net:   No ethernet found.
Hit key to stop autoboot('CTRL+C'):  0
## Booting FIT Image FIT: No fit blob
FIT: No FIT image
ANDROID: reboot reason: "(none)"
optee api revision: 2.0
TEEC: Waring: Could not find security partition
Not AVB images, AVB skip
No valid android hdr
Android image load failed
Android boot failed, error -1.
MMC error: The cmd index is 1, ret is -110
Card did not respond to voltage select!
mmc_init: -95, time 10
switch to partitions #0, OK
mmc0(part 0) is current device
Failed to mount ext2 filesystem...
starting USB...
Bus dwc3@fcc00000: usb maximum-speed not found
Register 2000140 NbrPorts 2
Starting the controller
USB XHCI 1.10
Bus dwc3@fd000000: usb maximum-speed not found
USB XHCI 1.10
scanning bus dwc3@fcc00000 for devices... 1 USB Device(s) found
scanning bus dwc3@fd000000 for devices... cannot reset port 1!?
Device 0: unknown device
No ethernet found.
missing environment variable: bootfile
Retrieving file: pxelinux.cfg/00000000
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
Retrieving file: pxelinux.cfg/default-arm-rockchip
No ethernet found.
No ethernet found.
No ethernet found.
Config file not found
No ethernet found.
No ethernet found.
Edited by mvpwar
Sorry @mvpwar
When I said v5 image
It's about the v0.5 flash drive image that I have done...
I'm not so good with instructions,
For me It's hard to give instructions over a forum topic, be better when I have the device to debug.
Flash the V5 update.IMG on device
And v0.5 SD image on flash drive over USB 3.0
Edited by hotnikq
I had found the problem, and I tried to flashing the other image rock3a_debian_buster_xfce4_arm64_20211113_0127-gpt.img, no work
Now I flashed your v0.5 SD image ,the same result @hotnikq
DRAM:  7.7 GiB
Sysmem: init
Hotkey: ctrl+`
MMC0: HS200, 200Mhz
PartType: EFI
boot mode: None
FIT: No fdt blob
Failed to load DTB
io-domain: OK
  apll 816000 KHz
  dpll 390000 KHz
  gpll 1188000 KHz
  cpll 1000000 KHz
  npll 24000 KHz
  vpll 24000 KHz
  hpll 24000 KHz
  ppll 100000 KHz
  armclk 816000 KHz
  aclk_bus 150000 KHz
  pclk_bus 50000 KHz
  hclk_top 150000 KHz
  pclk_top 50000 KHz
  pclk_pmu 50000 KHz
FIT: No FIT image
starting USB...
USB XHCI 1.10
USB XHCI 1.10
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
No ethernet found.
do you know how to type some command on ttl debug serial mode? I want to check mmc info, but I found the keyboard input can't interupt the u-boot booting, my box only connect the tx,rx,gnd, I remember it works when I ttl debug the orangepi3
You need to enable console tty over dtb command line
So it will wait for interaction
Since we use an original Android dtb on uboot.img
No console enabled 😅
I'm about to buy an 8gb box just to make this image, but I already have a lot of hardware sitting here, including a radxa rock 3A 8gb ram 64gb mmc 1tb nvme, that don't accelerate GPU 😂 (drivers), hardware waiting for some use, tomorrow I'm going to make a socks5 Proxy over isolated docker L3 lan on it just to prevent it from being at the bottom of the drawer
Edited by hotnikq
No need this interaction, I found I can not type the username and password while the debian10 init finished (this is interaction), I feel that I can't send any data to the ttl terminal
can you login the os at serial console when the os Initialization completed @hotnikq
Edited by mvpwar
26 minutes ago, hotnikq said:
Can you use the linaro build image to boot from USB? On 8gb device?
can boot from mmc...no need usb
I hadn't even boot kernel6.2, I don't know why you can boot the os without boot.img, it is so difficult @hotnikq
Edited by mvpwar
