Slycat34 Posted June 29, 2023 Posted June 29, 2023 Been having an issue where my idle temps are >60C The fan will spin for maybe a second or two and then turn off for 10-20 seconds Checking /sys/class/hwmon/hwmon2/pwm1 and it is set to 0 even though my MINPWM is set to 90 Even if I manually tee 90 to pwm1 it will eventually reset to 0 even with fancontrol turned off So something resetting without my input... fan1_input does read fan speed & pwm1_enabled is set to 1 lsof & auditd do not have any info as to what is overwriting the file Only way I can get the fan to stay on is to loop the tee command for a few seconds and then it is on that one speed Turning fancontrol back on works for a while and changes speed as expected but eventually pwm1 goes back to 0 I found that when pwm1 is between 90-125 it does runs fine but once higher than 125 it resets Then tried 125 as minimum and the working range becomes 125-160 before reset Then tried 170 as minimum and the working range becomes 175-220 before reset Could the fan be dying and the voltage/load send a signal to the kernel to say "shut down fan"? fancontrol INTERVAL= 10 DEVPATH= hwmon0=devices/virtual/thermal/thermal_zone0 hwmon2=devices/platform/pwm-fan DEVNAME= hwmon0=cpu_thermal hwmon2=pwmfan FCTEMPS=hwmon2/pwm1=hwmon0/temp1_input FCFANS=hwmon2/pwm1=hwmon2/fan1_input MINTEMP=hwmon2/pwm1=54 MAXTEMP=hwmon2/pwm1=65 MINSTART=hwmon2/pwm1=90 MINSTOP=hwmon2/pwm1=110 MINPWM=hwmon2/pwm1=90 MAXPWM=hwmon2/pwm1=240 tee command to force fan spin (only way to avoid resetting to zero), ctrl+c after a few seconds while true; do echo 90 | sudo tee /sys/class/hwmon/hwmon2/pwm1; done 0 Quote
arkhi Posted July 30, 2023 Posted July 30, 2023 (edited) My fan is behaving the same and I’m also wondering if I should plan its death soon. I see you have a `FCFANS` property in your config; the hc4 page on armbian states the following: Quote With kernel 5.15.y -> you need to remove FCFANS=hwmon2/pwm1=hwmon2/fan1_input in /etc/fancontrol So maybe something to consider? I removed it though, so that might be completely off‑topic. `man fancontrol` states “FCFANS Records the association between a PWM output and a fan input. Then fancontrol can check the fan speed and restart it if it stops unexpectedly”. Not sure if there is anything wrong and, if so, what is wrong, but I’d also be interested by an explanation if anyone has one. Edited July 30, 2023 by arkhi 0 Quote
bAL Posted August 7, 2023 Posted August 7, 2023 I'm experiencing the same thing after installing Debian Bookworm on RockPro64. The golden number to keep the fun running in my case is 99, anything above gets reset to 0. If I intentionally stress the CPU enough to drive high temperatures, the fan kicks in automatically with a value of 100, but that's too slow in my case. This is without any utilities like fancontrol installed. 0 Quote
bAL Posted August 7, 2023 Posted August 7, 2023 I was able to prevent the auto-reset by disabling thermal_zone0 on the board. got the idea from: https://forum.pine64.org/showthread.php?tid=6276&pid=45169#pid45169 After setting the mode to 'disabled', the pwm1 does not get reset anymore. Note that the next reboot will reset the value to 'enabled'. To make it permanent, I added a udev rule as suggested here: https://forum.manjaro.org/t/persisting-change-to-sys-class-thermal-thermal-zone-mode/53556 The rule in the post didn't work for me however and I went with: KERNEL=="thermal_zone0", SUBSYSTEM=="thermal", ATTR{mode}="disabled" 0 Quote
Semmu Posted December 16, 2025 Posted December 16, 2025 (edited) I just registered here to say thanks to @bAL, your solution works on my Odroid HC4. I was bashing my head against the wall because I couldn't find what was constantly changing the fan PWM value even after disabling the fancontrol service. Now I finally have full control over the fan PWM (and thus the noise levels). Thanks again! So yeah, this issue is still relevant in 2025. `lsb_release -a` output for the interested: Distributor ID: Debian Description: Armbian 25.11.2 trixie Release: 13 Codename: trixie Edited December 16, 2025 by Semmu 0 Quote
