Jarod Adolfo Posted July 6, 2023 Share Posted July 6, 2023 How to adjust the resolution of the armbian so that the display would fit I'm using a 3.2" ILI9341 TFT LCD I also followed this tutorial https://mobile4dev.blogspot.com/2017/09/orange-pi-pc-tft-ili9341.html 0 Quote Link to comment Share on other sites More sharing options...
Tim Steve Posted July 6, 2023 Share Posted July 6, 2023 Connect to your Armbian device via SSH or access its command line interface. Open the /boot/armbianEnv.txt file using a text editor. You can use the nano editor by running the following command: sudo nano /boot/armbianEnv.txt Look for the line that starts with disp_mode or extraargs. If you find extraargs, add disp_mode after it. Modify the line to include the appropriate display resolution. For example: extraargs=fbcon=map:10 console=ttyS0,115200 disp_mode=320x240 Save the changes and exit the text editor. In nano, you can press Ctrl + O to save and Ctrl + X to exit. Reboot your Armbian device for the changes to take effect. You can do this by running: sudo reboot After the reboot, the display resolution should be adjusted to fit your TFT LCD. 0 Quote Link to comment Share on other sites More sharing options...
