I am using Armbian 23.5 Jammy XFCE on a Tinker Board 2S. I have a number of issues to sort, one of them being display.
The display is receiving a 16:9 signal, but the right hand side of the screen is covered by a black-white-green pattern under which I can move windows (image attached).
How can I change the settings to avoid this?
Edited by Jonathan Till
Try selecting a different resolution from the display Setting list and see if it resolves the issue. Start with a resolution that matches the aspect ratio of your display (16:9). If the issue persists, try different resolutions to see if any of them work correctly.
