warbirdwollin Posted July 8, 2023 Posted July 8, 2023 (edited) So I am following instructions for how to install Kiauh on Arbmian. I am using a terminal on my PC through PuTTY. I have cloned the Kiauh files to my device successfully, I have verified they are there, but whenever I try to run the shell using sh ./kiauh/kiauh.sh I get the response 'unknown': I need something more specific. This is the least useful error message I have ever seen. I can't find anyone having had this issue and I am dead in the water. Any insight would be greatly appreciated! Edited July 8, 2023 by warbirdwollin 0 Quote
CryBaby Posted July 9, 2023 Posted July 9, 2023 You should ask on the kiauh github, I think the problem is kiauh not armbian. 0 Quote
Tim Steve Posted July 10, 2023 Posted July 10, 2023 You should double-check that you are in the correct directory when trying to run the script. You mentioned that you have cloned the Kiauh files successfully, so make sure you are in the root directory of the Kiauh files before executing the script. 0 Quote
