Dombo 71 Posted July 18, 2023 Posted July 18, 2023 Hope there is a option.. for install libssl1.1 Drive me cray. I run: ___ _ _ _ _ _ ____ / _ \ __| |_ __ ___ (_) __| | | \ | |___ \ | | | |/ _` | '__/ _ \| |/ _` | | \| | __) | | |_| | (_| | | | (_) | | (_| | | |\ |/ __/ \___/ \__,_|_| \___/|_|\__,_| |_| \_|_____| Welcome to Armbian 23.05.1 Bookworm with Linux 6.1.30-meson64 System load: 2% Up time: 31 min Memory usage: 9% of 3.69G IP: 192.168.5.70 CPU temp: 34°C Usage of /: 9% of 57G RX today: 499.3 MiB Last login: Tue Jul 18 01:39:33 2023 from 192.168.5.101 Fow my Domoticz, in need, libssl1.1 Still get an error when run: pi@Domoticz:~$ cd domoticz pi@Domoticz:~/domoticz$ ./domoticz ./domoticz: error while loading shared libraries: libssl.so.1.1: cannot open shared object file: No such file or directory pi@Domoticz:~/domoticz$ Where i google and try to find solutions.. No option to install libssl1.1 on my ondroid. [ also not with jammy ] Help please...... THANKS!!! 0 Quote
mitu Posted July 18, 2023 Posted July 18, 2023 You'll need to install it from source the binary releases don't seem to support the newer OpenSSL3 libraries, see https://github.com/domoticz/domoticz/issues/5233, 0 Quote
Dombo 71 Posted July 18, 2023 Author Posted July 18, 2023 I try this options also. Not working. Perhaps other options? Or is this just a domotcz problem? And need domoticz change something? 0 Quote
mitu Posted July 18, 2023 Posted July 18, 2023 This is a domoticz issue, if you're unable to install from source then ask for support in their forums (or whatever they use for support). The issue is not specific to Armbian. 0 Quote
Sergey Kostromin Posted December 7, 2023 Posted December 7, 2023 (edited) try this wget http://security.debian.org/debian-security/pool/updates/main/o/openssl/libssl1.1_1.1.1n-0+deb11u5_arm64.deb sudo dpkg -i libssl1.1_1.1.1n-0+deb11u5_arm64.deb then install domoticz it also worked fine after install for me. My system Armbian 23.11.0-trunk Lunar with bleeding edge Linux 6.6.2-edge-meson on Amlogic S912 Edited December 7, 2023 by Sergey Kostromin 0 Quote
Kaeter Posted April 16, 2025 Posted April 16, 2025 Small change on the .deb link in case it is missing. I was using this link for the wget: https://security.debian.org/debian-security/pool/updates/main/o/openssl/libssl-dev_1.1.1n-0+deb10u6_arm64.deb And it does make my domoticz install script works. Thanks to Sergey for the guide🙏. 0 Quote
