Missing GPIO on Armbian for BananaPI M2B
Go to solution Solved by WernherVonData,
Just started playing with BananaPi (I have M2Berry model) and installed Armbian from Armbian download page: Armbian_23.5.2_Bananapim2ultra_bookworm_current_6.1.30_minimal (connecting with board over UART/SSH - no need for desktop at this moment).
Wanted to use GPIO, however using sysfs do not work as expected:
root@bananapim2ultra:~# echo "24" > /sys/class/gpio/export
-bash: echo: write error: Unknown error 517
-bash: echo: write error: Device or resource busy
Went with lsmod to check modules but having only:
root@bananapim2ultra:~# lsmod | grep gp
gpu_sched              28672  1 lima
Same for modprobe:
root@bananapim2ultra:~# modprobe gpio
modprobe: FATAL: Module gpio not found in directory /lib/modules/6.1.30-sunxi
It looks like the kernel do not have gpio module, which is really strange since the GPIO is main feature for such boards. Running armbian-config - maybe I will find something.
Can somebody help me out a little with it?
Edited by WernherVonData
  • Solution
Never mind. Solved it.
Went here: https://linux-sunxi.org/GPIO (this image is on sunxi kernel, probably for other kernels it might be different).
Checked this file
cat /sys/kernel/debug/pinctrl/*/pinmux-pins
And there finally I was able to know which pin on the board is mapped to which port in the system. 24 is not on that list, thus it was raising an error.
Then just went with the libgpiod library and the magic happened.
