Armbian 23.08.0-trunk Bookworm with Linux 5.10.160-rk35xx
root@orangepi5-plus:~# gpio -v
gpio version: 2.46
Copyright (c) 2012-2018 Gordon Henderson
This is free software with ABSOLUTELY NO WARRANTY.
For details type: gpio -warranty
  * Device tree is enabled.
  *--> Orange Pi 5 Plus
root@orangepi5-plus:~# gpio readall
wiringPiSetup: mmap (GPIO) failed: Operation not permitted
Hello!
I also have this issue!
I believe it's a kernel flag to allow read/write of dev/mem
Anyway of changing that without compiling a custom kernel?
Strace log
root@orangepi5-plus:~# strace gpio readall
execve("/usr/local/bin/gpio", ["gpio", "readall"], 0xffffd664ff88 /* 21 vars */) = 0
brk(NULL)                               = 0xaaaac110a000
mmap(NULL, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0xffff8f698000
faccessat(AT_FDCWD, "/etc/ld.so.preload", R_OK) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/etc/ld.so.cache", O_RDONLY|O_CLOEXEC) = 3
newfstatat(3, "", {st_mode=S_IFREG|0644, st_size=99325, ...}, AT_EMPTY_PATH) = 0
mmap(NULL, 99325, PROT_READ, MAP_PRIVATE, 3, 0) = 0xffff8f64b000
close(3)                                = 0
openat(AT_FDCWD, "/usr/local/lib/libwiringPi.so", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0\267\0\1\0\0\0\0\0\0\0\0\0\0\0"..., 832) = 832
newfstatat(3, "", {st_mode=S_IFREG|0755, st_size=154496, ...}, AT_EMPTY_PATH) = 0
mmap(NULL, 266552, PROT_NONE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0xffff8f609000
mmap(0xffff8f610000, 201016, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0) = 0xffff8f610000
munmap(0xffff8f609000, 28672)           = 0
munmap(0xffff8f642000, 33080)           = 0
mprotect(0xffff8f627000, 61440, PROT_NONE) = 0
mmap(0xffff8f636000, 40960, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x16000) = 0xffff8f636000
mmap(0xffff8f640000, 4408, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0xffff8f640000
close(3)                                = 0
openat(AT_FDCWD, "/usr/local/lib/libwiringPiDev.so", O_RDONLY|O_CLOEXEC) = 3
newfstatat(3, "", {st_mode=S_IFREG|0755, st_size=37016, ...}, AT_EMPTY_PATH) = 0
mmap(NULL, 167040, PROT_NONE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0xffff8f5e7000
mmap(0xffff8f5f0000, 101504, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0) = 0xffff8f5f0000
munmap(0xffff8f5e7000, 36864)           = 0
munmap(0xffff8f609000, 27776)           = 0
mprotect(0xffff8f5f6000, 61440, PROT_NONE) = 0
mmap(0xffff8f605000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x5000) = 0xffff8f605000
mmap(0xffff8f607000, 7296, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0xffff8f607000
close(3)                                = 0
openat(AT_FDCWD, "/lib/aarch64-linux-gnu/libc.so.6", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\3\0\0\0\0\0\0\0\0\3\0\267\0\1\0\0\0\340u\2\0\0\0\0\0"..., 832) = 832
newfstatat(3, "", {st_mode=S_IFREG|0644, st_size=1641496, ...}, AT_EMPTY_PATH) = 0
mmap(NULL, 1810024, PROT_NONE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0xffff8f436000
mmap(0xffff8f440000, 1744488, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0) = 0xffff8f440000
munmap(0xffff8f436000, 40960)           = 0
munmap(0xffff8f5ea000, 24168)           = 0
mprotect(0xffff8f5c9000, 61440, PROT_NONE) = 0
mmap(0xffff8f5d8000, 24576, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x188000) = 0xffff8f5d8000
mmap(0xffff8f5de000, 48744, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0xffff8f5de000
close(3)                                = 0
openat(AT_FDCWD, "/lib/aarch64-linux-gnu/libm.so.6", O_RDONLY|O_CLOEXEC) = 3
newfstatat(3, "", {st_mode=S_IFREG|0644, st_size=551064, ...}, AT_EMPTY_PATH) = 0
mmap(NULL, 680048, PROT_NONE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0xffff8f399000
mmap(0xffff8f3a0000, 614512, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0) = 0xffff8f3a0000
munmap(0xffff8f399000, 28672)           = 0
munmap(0xffff8f437000, 32880)           = 0
mprotect(0xffff8f426000, 61440, PROT_NONE) = 0
mmap(0xffff8f435000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x85000) = 0xffff8f435000
close(3)                                = 0
openat(AT_FDCWD, "/lib/aarch64-linux-gnu/libcrypt.so.1", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0\267\0\1\0\0\0\20\25\0\0\0\0\0\0"..., 832) = 832
newfstatat(3, "", {st_mode=S_IFREG|0644, st_size=186296, ...}, AT_EMPTY_PATH) = 0
mmap(NULL, 348512, PROT_NONE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0xffff8f34a000
mmap(0xffff8f350000, 282976, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0) = 0xffff8f350000
munmap(0xffff8f34a000, 24576)           = 0
munmap(0xffff8f396000, 37216)           = 0
mprotect(0xffff8f37d000, 61440, PROT_NONE) = 0
mmap(0xffff8f38c000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x2c000) = 0xffff8f38c000
mmap(0xffff8f38e000, 29024, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0xffff8f38e000
close(3)                                = 0
mmap(NULL, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0xffff8f696000
set_tid_address(0xffff8f696b10)         = 11233
set_robust_list(0xffff8f696b20, 24)     = 0
rseq(0xffff8f6971e0, 0x20, 0, 0xd428bc00) = 0
mprotect(0xffff8f5d8000, 16384, PROT_READ) = 0
mprotect(0xffff8f38c000, 4096, PROT_READ) = 0
mprotect(0xffff8f435000, 4096, PROT_READ) = 0
mprotect(0xffff8f605000, 4096, PROT_READ) = 0
mprotect(0xffff8f636000, 4096, PROT_READ) = 0
mprotect(0xaaaaab06d000, 4096, PROT_READ) = 0
mprotect(0xffff8f69d000, 8192, PROT_READ) = 0
prlimit64(0, RLIMIT_STACK, NULL, {rlim_cur=8192*1024, rlim_max=RLIM64_INFINITY}) = 0
munmap(0xffff8f64b000, 99325)           = 0
geteuid()                               = 0
getrandom("\x97\x05\x6a\x79\xe5\x03\x78\xac", 8, GRND_NONBLOCK) = 8
brk(0xaaaac112b000)                     = 0xaaaac112b000
openat(AT_FDCWD, "/etc/orangepi-release", O_RDONLY) = -1 ENOENT (No such file or directory)
openat(AT_FDCWD, "/etc/armbian-release", O_RDONLY) = 3
newfstatat(3, "", {st_mode=S_IFREG|0644, st_size=464, ...}, AT_EMPTY_PATH) = 0
read(3, "# PLEASE DO NOT EDIT THIS FILE\nB"..., 4096) = 464
close(3)                                = 0
openat(AT_FDCWD, "/dev/mem", O_RDWR|O_SYNC|O_CLOEXEC) = 3  #ERROS HERE -dan
mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_SHARED, 3, 0x300b000) = -1 EPERM (Operation not permitted)
write(2, "wiringPiSetup: mmap (GPIO) faile"..., 59wiringPiSetup: mmap (GPIO) failed: Operation not permitted
) = 59
exit_group(1)                           = ?
+++ exited with 1 +++
I've just compiled a new kernel with almost the default config, the things I've changed have nothing to do with access to the GPIO pins and I've never seen these errors. What have you tried? Did you install the right branch of Wiringpi?
git clone https://github.com/orangepi-xunlong/wiringOP.git --branch next
cd wiringOP
./build clean
./build
Then just run "GPIO read all"
Works here without root, perhaps the default user groups have been changed? But first see if this works.
