Could you explain a bit more about your procedures?
SSH is something basic that should just work.
Are you using wifi or ethernet? Is the guest device on windows, linux or OSX? What software are you using?
Can you try an image from the archive to see if it's better? https://armbian.hosthatch.com/archive/
Are you sure the OPi0 is booted? It might be power cycling if you've got a bad PSU.
Best way to debug would be to use uart.
You could also use your router its webpage to see if it's on, and what IP address is used. Maybe it's switching ip? To do that use "ip a" on linux or "ipconfig" on windows to see the default gateway. Then type that in a browser. Look on your router if there's a username and password.
Many reasons I could think of, but without enough info there's no way to know. Good luck.
