Georges-David Attali Posted November 24, 2016 Posted November 24, 2016 Hello, would it be possible to integrate WPS on boot by default on SD Card images proposed for download. This would ease the setup, especially on small devices without RJ45 plug ! Thanks.
tkaiser Posted November 24, 2016 Posted November 24, 2016 would it be possible to integrate WPS on boot by default on SD Card images proposed for download. You mean this WPS here? https://en.wikipedia.org/wiki/Wi-Fi_Protected_Setup#Vulnerabilities This would ease the setup, especially on small devices without RJ45 plug ! Those two boards that have no Ethernet have serial console on their USB OTG port enabled, Plug a NanoPi Air in an USB port of your computer, do a screen /dev/cu.usb* 115200 and you're in: nanopiair login: tk Password: Last login: Thu Nov 24 14:37:57 UTC 2016 on ttyGS0 _ _ ____ _ _ _ | \ | | __ _ _ __ ___ | _ \(_) / \ (_)_ __ | \| |/ _` | '_ \ / _ \| |_) | | / _ \ | | '__| | |\ | (_| | | | | (_) | __/| | / ___ \| | | |_| \_|\__,_|_| |_|\___/|_| |_| /_/ \_\_|_| Welcome to ARMBIAN Ubuntu 16.04.1 LTS 3.4.112-sun8i System load: 0.01 Up time: 1 hour Memory usage: 5 % of 494Mb IP: 192.168.83.149 CPU temp: 30°C Usage of /: 17% of 7.1G [ 6 updates to install: apt-get upgrade ] tk@nanopiair:~$ w 16:07:43 up 1:36, 1 user, load average: 0.00, 0.02, 0.05 USER TTY FROM LOGIN@ IDLE JCPU PCPU WHAT tk ttyGS0 16:05 1.00s 0.60s 0.05s w
