kingOnename Posted August 8, 2023 Posted August 8, 2023 Hello all, I'm trying to setup libwc (preferred) or weston on my Mekotronics R58X (2023 edition) But when I try and build any wayland compositor, I keep gettign this error: ERROR: Dependency "wayland-server" not found, tried pkgconfig and cmake But I appear to be running wayland: mekotronics-r58x:weston:% echo $XDG_SESSION_TYPE <main> wayland And when I search for it in apt, I'm only seeing libwayland installed/available: mekotronics-r58x:weston:% apt search wayland-server <main> Sorting... Done Full Text Search... Done librust-wayland-commons-dev/jammy 0.29.1-1 arm64 Common types and structures used by wayland-client and wayland-server - Rust source code libwayland-server0/jammy-security,jammy-updates,now 1.20.0-1ubuntu0.1 arm64 [installed,automatic] wayland compositor infrastructure - server library I've tried installing libwc: https://github.com/labwc/labwc but in order to do that I have to install wlroot--and I get the same error when trying to build I've also tried weston: https://gitlab.freedesktop.org/wayland/weston My overall goal is to have a basic window compositor launch kodi in fullscreen on start--but also let's me run other applications. Please advise if you have any input, or if I am missing something Hardware: Mekotronics R58X (2023 edition) OS: Armbian (23.08.420-monka) aarch64 Host: Mekotronics R58X (RK3588 EDGE LP4x V1.0 BlueBerry Board) Kernel: 5.10.160-rk35xx Shell: zsh 5.8.1 Resolution: 3840x2160 DE: GNOME 42.9 WM: Mutter CPU: (8) @ 1.800GHz Memory: 2917MiB / 15970MiB CPU Usage: 11% Thank you, 0 Quote
hyyoxhk Posted December 21, 2023 Posted December 21, 2023 Hello,do you succeed? I'm doing the same thing, I ported wlroots-0.16 and labwc-0.6.2, but it will generate segmentation fault when I run a client App of Qt (myqtexample -platform wayland) 0 Quote
kingOnename Posted November 22, 2024 Author Posted November 22, 2024 @hyyoxhk no. But I'm hoping enough time has passed for me to try again and succeed lol. Hopefully there's since been more Wayland development 0 Quote
robertoj Posted July 7 Posted July 7 labwc is available in debian trixie: Start with a minimal armbian install Make sure your /dev/fb0 is DRM, not framebuffer $ sudo apt install seatd labwc foot $ labwc -s foot 0 Quote
