I'm trying to use the WiFi module included with the Orange Pi PC Plus, when I try connect to a WiFi network (using just iwconfig and 'ifconfig wlan0 up') it doesn't connect, resulting in a kernel panic.
[ 1029.575558] ------------[ cut here ]------------
[ 1029.591494] WARNING: at net/wireless/sme.c:531 cfg80211_connect_result+0x50/0x120()
[ 1029.611113] Modules linked in: bnep bluetooth sunxi_cir pcf8591 bmp085 8189fs [last unloaded: scsi_wait_scan]
[ 1029.611234] [<c0016a20>] (unwind_backtrace+0x0/0xe8) from [<c0687850>] (dump_stack+0x20/0x24)
[ 1029.611283] [<c0687850>] (dump_stack+0x20/0x24) from [<c0029720>] (warn_slowpath_common+0x5c/0x74)
[ 1029.611328] [<c0029720>] (warn_slowpath_common+0x5c/0x74) from [<c00297f4>] (warn_slowpath_null+0x2c/0x34)
[ 1029.611376] [<c00297f4>] (warn_slowpath_null+0x2c/0x34) from [<c0676ce4>] (cfg80211_connect_result+0x50/0x120)
[ 1029.611704] [<c0676ce4>] (cfg80211_connect_result+0x50/0x120) from [<bf0570cc>] (rtw_cfg80211_indicate_connect+0x1e8/0x1f0 [8189fs])
[ 1029.612170] [<bf0570cc>] (rtw_cfg80211_indicate_connect+0x1e8/0x1f0 [8189fs]) from [<bf052ba8>] (rtw_os_indicate_connect+0x3c/0x70 [8189fs])
[ 1029.612588] [<bf052ba8>] (rtw_os_indicate_connect+0x3c/0x70 [8189fs]) from [<bf016fc0>] (rtw_indicate_connect+0x38/0x54 [8189fs])
[ 1029.612965] [<bf016fc0>] (rtw_indicate_connect+0x38/0x54 [8189fs]) from [<bf018bc0>] (rtw_joinbss_event_prehandle+0x464/0x508 [8189fs])
[ 1029.613348] [<bf018bc0>] (rtw_joinbss_event_prehandle+0x464/0x508 [8189fs]) from [<bf0235c0>] (report_join_res+0xc0/0xd0 [8189fs])
[ 1029.613735] [<bf0235c0>] (report_join_res+0xc0/0xd0 [8189fs]) from [<bf023824>] (OnAssocRsp+0x254/0x264 [8189fs])
[ 1029.614112] [<bf023824>] (OnAssocRsp+0x254/0x264 [8189fs]) from [<bf019afc>] (_mgt_dispatcher+0x94/0x9c [8189fs])
[ 1029.614486] [<bf019afc>] (_mgt_dispatcher+0x94/0x9c [8189fs]) from [<bf01aba8>] (mgt_dispatcher+0x1a4/0x1c8 [8189fs])
[ 1029.614879] [<bf01aba8>] (mgt_dispatcher+0x1a4/0x1c8 [8189fs]) from [<bf02fdfc>] (validate_recv_mgnt_frame+0x158/0x17c [8189fs])
[ 1029.615290] [<bf02fdfc>] (validate_recv_mgnt_frame+0x158/0x17c [8189fs]) from [<bf02ff10>] (validate_recv_frame+0xf0/0x148 [8189fs])
[ 1029.615701] [<bf02ff10>] (validate_recv_frame+0xf0/0x148 [8189fs]) from [<bf030f44>] (recv_func_prehandle+0x54/0x78 [8189fs])
[ 1029.616110] [<bf030f44>] (recv_func_prehandle+0x54/0x78 [8189fs]) from [<bf03109c>] (recv_func+0x80/0x138 [8189fs])
[ 1029.616518] [<bf03109c>] (recv_func+0x80/0x138 [8189fs]) from [<bf031178>] (rtw_recv_entry+0x24/0x64 [8189fs])
[ 1029.616971] [<bf031178>] (rtw_recv_entry+0x24/0x64 [8189fs]) from [<bf07f884>] (rtl8188fs_recv_tasklet+0x344/0x3d0 [8189fs])
[ 1029.617246] [<bf07f884>] (rtl8188fs_recv_tasklet+0x344/0x3d0 [8189fs]) from [<c00315f4>] (tasklet_action+0xb4/0x120)
[ 1029.617297] [<c00315f4>] (tasklet_action+0xb4/0x120) from [<c00309e0>] (__do_softirq+0xe4/0x240)
[ 1029.617343] [<c00309e0>] (__do_softirq+0xe4/0x240) from [<c0030f88>] (irq_exit+0x58/0xa4)
[ 1029.617388] [<c0030f88>] (irq_exit+0x58/0xa4) from [<c000ef58>] (handle_IRQ+0x90/0xbc)
[ 1029.617431] [<c000ef58>] (handle_IRQ+0x90/0xbc) from [<c000853c>] (gic_handle_irq+0x4c/0x6c)
[ 1029.617474] [<c000853c>] (gic_handle_irq+0x4c/0x6c) from [<c000db40>] (__irq_svc+0x40/0x74)
[ 1029.617500] Exception stack(0xef0a7e48 to 0xef0a7e90)
[ 1029.617531] 7e40:                   c1475780 eebb4740 c09d1520 00000000 eebb4740 ee9c0e40
[ 1029.617568] 7e60: 00000002 c1475780 88ca30c2 ee9c0e40 00000000 ef0a7e9c ef0a7ea0 ef0a7e90
[ 1029.617598] 7e80: c0055d88 c0690c18 60000013 ffffffff
[ 1029.617640] [<c000db40>] (__irq_svc+0x40/0x74) from [<c0690c18>] (_raw_spin_unlock_irq+0x2c/0x58)
[ 1029.617689] [<c0690c18>] (_raw_spin_unlock_irq+0x2c/0x58) from [<c0055d88>] (finish_task_switch+0x48/0x120)
[ 1029.617736] [<c0055d88>] (finish_task_switch+0x48/0x120) from [<c068fc20>] (__schedule+0x590/0x7fc)
[ 1029.617780] [<c068fc20>] (__schedule+0x590/0x7fc) from [<c068ff1c>] (schedule+0x90/0x94)
[ 1029.617823] [<c068ff1c>] (schedule+0x90/0x94) from [<c069030c>] (schedule_preempt_disabled+0x30/0x40)
[ 1029.617870] [<c069030c>] (schedule_preempt_disabled+0x30/0x40) from [<c0030bbc>] (run_ksoftirqd+0x80/0x190)
[ 1029.617920] [<c0030bbc>] (run_ksoftirqd+0x80/0x190) from [<c0049c58>] (kthread+0x94/0xa0)
[ 1029.617967] [<c0049c58>] (kthread+0x94/0xa0) from [<c000f1b0>] (kernel_thread_exit+0x0/0x8)
[ 1029.617994] ---[ end trace 11986543d997a627 ]---
Linux orangepipcplus 3.4.112-sun8i #10 SMP PREEMPT Sun Oct 23 16:06:55 CEST 2016 armv7l GNU/Linux
Distributor ID: Debian
Description:    Debian GNU/Linux 8.6 (jessie)
Release:        8.6
Codename:       jessie
All packages are updated. I'm also connected via Ethernet, I can disable it and try using the serial port if its necessary.
