On 10/20/2025 at 5:10 PM, emor acid said:
hi, Compilation error, I also decompiled the dts available for Android for reference
update armbian dts  ,Give to those in need
use sudo  armbian-add-overlay ***.dts
this dts can avaible  rtl8211f on h618
/dts-v1/;
/plugin/;
    compatible = "allwinner,sun50i-h618";
    fragment@0 {
        target = <&mmc1>;
        __overlay__ {
            status = "disabled";
    fragment@1 {
        target = <&emac1>;
        __overlay__ {
    fragment@2 {
        target = <&pio>;
        __overlay__ {
            x98h_rgmii_pins: x98h-rgmii-pins {
                pins = "PI0", "PI1", "PI2", "PI3", "PI4", "PI5", "PI6", "PI7", "PI8", "PI9", "PI10", "PI11", "PI12", "PI13", "PI14", "PI15";
                function = "emac0";
                drive-strength = <40>;
    /* 3. 配置千兆网卡 */
    fragment@3 {
        target = <&emac0>;
        __overlay__ {
            pinctrl-names = "default";
            pinctrl-0 = <&x98h_rgmii_pins>;
            phy-mode = "rgmii";
            phy-handle = <&rgmii_phy>;
            phy-io-supply = <&reg_aldo1>;
            allwinner,tx-delay-ps = <700>;
            allwinner,rx-delay-ps = <3100>;
            status = "okay";
            mdio {
                rgmii_phy: ethernet-phy@1 {
                    compatible = "ethernet-phy-ieee802.3-c22";
                    reg = <1>;
                    reset-gpios = <&pio 8 16 1>;
                    reset-assert-us = <30000>;
                    reset-deassert-us = <150000>;
 Build from branch v20250306.
error! [ Failed to fetch SHA1 of 'https://git.kernel.org/pub/scm/linux/kernel/git/stable/linux.git' 'tag' 'v6.12.11' - make sure it's correct  ]
How to remove the error?
