Nick A Posted April 18 Share Posted April 18 (edited) Hi Dave, I don't see any difference between our dts (That deal with hdmi/audio). Maybe the overlay dtbo_a changed something.? If you can extract that. Have you tried your box with different TV/monitors and hdmi cables? Here's my dts. devicetree.dts Edited April 18 by Nick A 0 Quote Link to comment Share on other sites More sharing options...
Dave2024 Posted April 18 Share Posted April 18 Hi Nick. I'm on a business trip now, I'll be able to check on Monday. Maybe I'm just not assembling the firmware correctly? I’ll try to compile it again and publish the output of dmesg or whatever you suggest to understand the problem. Thank you very much for your time and help. 0 Quote Link to comment Share on other sites More sharing options...
wulfy23 Posted April 20 Share Posted April 20 (edited) On 4/18/2024 at 1:49 PM, Nick A said: Here's the latest build Thanks!, saved me significant messing around. Generic-ish "T95MAX"(lol) here, 4GB... bridged UART rx FET Source Drain but no luck with that... mounted SD to setup some credentials. Don't really use HDMI, BTOOTH, WIFI(rarely) but I owe you(s) one so if you need something let me know... edit: board is one where BTOOTH seems like it works and WIFI does not due to new brcm chipset etc. etc. Edited April 20 by wulfy23 board specifics 0 Quote Link to comment Share on other sites More sharing options...
afiftyp Posted April 21 Share Posted April 21 A bss138 FET or something similar can be used. 1 Quote Link to comment Share on other sites More sharing options...
Long Vũ Posted April 23 Share Posted April 23 Can I ask if there is a build for 2gb ram? I'm using Vontar 618 with board vs Transpeed 8k 2gb version so it almost just hangs on the armbian logo. I have tried all versions of armdev build but they don't work 0 Quote Link to comment Share on other sites More sharing options...
Nick A Posted April 24 Share Posted April 24 Hi Long Vu, you should install a UART Serial port so we can find out where it hangs. 0 Quote Link to comment Share on other sites More sharing options...
CaoSaMac Posted April 25 Share Posted April 25 Hi Long Vu . I use Vontar H618 2GB ram. it's running well with armbian 6.7.10 . only need to fix wifi driver 0 Quote Link to comment Share on other sites More sharing options...
Dmitriy Geels Posted April 25 Share Posted April 25 Manged to boot latest armbian on Transpeed T98 6K clone. Don't quite understand actions needed to boot from SD card, but investigating uBoot setup I noticed, that it can also boot from USB stick. I'd like to join the development. Device looks promising. 0 Quote Link to comment Share on other sites More sharing options...
CaoSaMac Posted Wednesday at 11:31 AM Share Posted Wednesday at 11:31 AM How can i flash to internal memory . it's better Sd card 0 Quote Link to comment Share on other sites More sharing options...
Nick A Posted yesterday at 01:48 AM Share Posted yesterday at 01:48 AM I have a patch for emmc internal memory but I haven't tested it yet. I got it from warpme's miniarch distro. If you go back a few pages you'll see how heiko910 installed to emmc. 0 Quote Link to comment Share on other sites More sharing options...
Владимир Владимиров Posted 13 hours ago Share Posted 13 hours ago Цитата Nick A Опубликовано: 18 апреля Here's the latest build if anyone wants to test it out. https://armdev.pixeldrift.net/transpeed/8k618-t/ I downloaded PRxxxx_20240415_db21e5f7d_Arabian-unofficial_24.5.0-trunk_Transpeed-8k618-t_bookworm_edge_6.7.12_xfce_desktop.tar. xz 2024-04-17 14:51 964M. I used Rufus to write to SD.When turned on, the Arabian download started. When the desktop appeared, I ran arm bin-config and installed arabian in the internal memory. I deleted the SD card on reboot. The system booted from the internal memory. WI-FI and BT are not working. Everything else works very fast. 0 Quote Link to comment Share on other sites More sharing options...
elysiuM Posted 13 hours ago Share Posted 13 hours ago Hi all. I have transpeed m98-8k plus allwinner h618. Its stop working. When i plug to power its only red light. Trying to flash stock firmware with phoenix suit, phoenix usb pro but stops when reach 45%. When i plug usb to USB1 port automatically start flashing. In livesuit says invalid image file. 0 Quote Link to comment Share on other sites More sharing options...
