DX9999 Posted August 23, 2023 Share Posted August 23, 2023 After flashing the sd card with armbian and booting it, it asks me to enter the root password, however the keyboard that is plugged in isnt detected and nothing is typed on the screen. Ive already tried bookworm and jammy, both cli and minimal-cli variants. It is not a keyboard or usb related issue, i tested it with an older version of armbian and the keyboard still works. 0 Quote Link to comment Share on other sites More sharing options...
Gunjan Gupta Posted August 23, 2023 Share Posted August 23, 2023 Could you please specify which armbian image version you experienced the issue with and what was the older version that worked for you? 0 Quote Link to comment Share on other sites More sharing options...
Raoul Posted August 23, 2023 Share Posted August 23, 2023 Hi, I got the same issue with bookworm images. After some research i found that usb otg is not enable. 0 Quote Link to comment Share on other sites More sharing options...
DX9999 Posted August 25, 2023 Author Share Posted August 25, 2023 Huh, when text first pops up on screen it says that its armbian jammy 23.05.1, but on the login it says its jammy 23.5.2. Also why would the usb otg be disabled? The M2 zero has only one usb port so without the otg its completely useless... weird 0 Quote Link to comment Share on other sites More sharing options...
Raoul Posted August 25, 2023 Share Posted August 25, 2023 (edited) I have a doubt with my power supply, When I boot up, the Numlock led of my keyboard light up then it's turn off some seconds later. I will do some tests in the next days. It's in this post that I was thinking usb otg is not enable: Edited August 25, 2023 by Raoul 0 Quote Link to comment Share on other sites More sharing options...
DX9999 Posted August 25, 2023 Author Share Posted August 25, 2023 I think i found an archive if older versions here https://xogium.performanceservers.nl/archive/bananapim2zero/archive/ 0 Quote Link to comment Share on other sites More sharing options...
pepar Posted September 15, 2023 Share Posted September 15, 2023 In case anyone stumbles upon this thread, check this one https://forum.armbian.com/topic/30140-banana-pi-m2-zero-otg-port-not-working-with-keyboard/ for answers. Hope this helps. Keep tinkering 0 Quote Link to comment Share on other sites More sharing options...
foo-keeper Posted February 1 Share Posted February 1 Check section 'USB Ethernet' on https://wiki.banana-pi.org/Getting_Started_with_M2_Zero Only the inner USB Port will work with Keyboard. 0 Quote Link to comment Share on other sites More sharing options...
