[Armbian build PR] - [WIP] Linux 6.5 support for Allwinner boards
Description
This brings early support for Linux kernel v6.5 for allwinner boards. Following patches are changed
Megous patches:
  • disabled patches.megous/video-fbdev-eInk-display-driver-for-A13-based-PocketBooks.patch to prevent build failure. Will work on re-enabling the same
Fixes patches:
  • disabled Fix-depends-only-ARM-eInk-display-FB.patch as it changes code introduce by patch disabled above
Armbian patches:
  • disabled drv-clk-sunxi-ng-ccu-sun50i-a64-revert-ccu-Pinebook-A64.patch due to patch application failure. Will check if its still needed. Need help from someone who has a PInebook A64 for the same.
  • removed drv-pmic-add-axp313a.patch as it is upstreamed
  • reworked the overlay support patches to reuse the upstream dtbo support. Due to this rework, overlay patches are updated to use dtso as the file extension
Config change:
  • Enabled CW1200 wireless driver as this might bring support for xradio xr819 due to patches from megous kernel
How Has This Been Tested?
  • [X] Build succeeds
Checklist:
  • [ ] My code follows the style guidelines of this project
  • [ ] I have performed a self-review of my own code
  • [ ] I have made corresponding changes to the documentation
  • [X] My changes generate no new warnings
View the full article
