Hi, my orange pi 5 plus cant boot armbian, its hang and screen goes flicker, im currently not been able to boot android images to (its hang and flicker to),, i cant boot armbian and android version.. but other linux is normally booting fine.. any advise?
What is the display it's default resolution? WIth displays other than 1080p/1440p/4k you can have problems. Example 1,366 × 768.
Or with VGA to HDMI adapters there can be problems.
Also I'd try another HDMI cable if using HDMI.
What image are you using?
For the plus you need to use these. https://xogium.performanceservers.nl/dl/orangepi5-plus/archive/
Debugging with UART would be helpful to see what's happening.
already tried different lcd display, but no luck,
my image was - Armbian_23.5.5_Orangepi5-plus_bookworm_legacy_5.10.160_minimal.img.xz
so my board wasn`t be able to boot armbian and android image, its goes crash and screen flicker and the rgb indicator light was not blinking, just red.
maybe need to debug using UART.
