Gwen Lg Posted September 10, 2023 Share Posted September 10, 2023 Hello, after some u-boot test, my helios64 don't start the bootloader stage. I can etablish a serial connection on USB Type-c port, but when I tried to start the system, I have no output on it. After I disconnected everything : - I connect usb-c cable, I'm able to connect to serial console with picocom - I connect the power cable, The LED1 (System Rail Power) is on, and the LED9 (Battery Status) flashes. - I press the power botton (without sdcard) : - LED2 and LED3 (Periph. Rail Power and HDD Rail Power) are on - LED4 and LED5 (System ON and HDD Activity) are on. - nothing happen on serial console - If I keep SWI (power botton pressed 5 seconds, i'm able to shutdown the system. I also follow the process of Maskrom Mode (https://wiki.kobol.io/helios64/maskrom/) with success, with no difference at end. > $ sudo tools/rkdeveloptool db rk3399_loader_v1.24_RevNocRL.126.bin > Downloading bootloader succeeded. > $ sudo tools/rkdeveloptool wl 0 /mnt/astav/distrib/Helios64/Armbian_21.05.1_Helios64_buster_current_5.10.35.img > Write LBA from file (100%) > $ sudo tools/rkdeveloptool rd > Reset Device OK. Questions : - What is the role of SPI Flash in the boot process ? - Does the SPI Flash can be erased ? And if yes, this can be affect the boot process ? - Can we supposed to be able to boot the armbian image writen on sd-card with SPI FLash skipped from the boot ? (with P11 jumper closed) - Could the Maskmode procedure help me, or allow me to repair my card ? - u-boot TPL is supposed to be writed on armbian sdcard ? - armbian image (like Armbian_21.05.1_Helios64_buster_current_5.10.35.img) are supposed to be able to boot, even when SPI and eMMc boot are skipped ? Thank you in advance for any help you can give me 0 Quote Link to comment Share on other sites More sharing options...
Gwen Lg Posted September 11, 2023 Author Share Posted September 11, 2023 (edited) I have do again the process of Maskrom Mode, but this time I write the helios64_sdcard_u-boot-only.img image. And after this (not 100% sure of the link) I was able to start again the Armbian + OMV system on my helios64. It's also seems than i have more information dump on serial console than before. Before the u-boot process I have this informations dumped : DDR Version 1.24 20191016 In channel 0 CS = 0 MR0=0x18 MR4=0x1 MR5=0x1 MR8=0x10 MR12=0x72 MR14=0x72 MR18=0x0 MR19=0x0 MR24=0x8 MR25=0x0 channel 1 CS = 0 MR0=0x18 MR4=0x1 MR5=0x1 MR8=0x10 MR12=0x72 MR14=0x72 MR18=0x0 MR19=0x0 MR24=0x8 MR25=0x0 channel 0 training pass! channel 1 training pass! change freq to 416MHz 0,1 Channel 0: LPDDR4,416MHz Bus Width=32 Col=10 Bank=8 Row=16 CS=1 Die Bus-Width=16 Size=2048MB Channel 1: LPDDR4,416MHz Bus Width=32 Col=10 Bank=8 Row=16 CS=1 Die Bus-Width=16 Size=2048MB 256B stride channel 0 CS = 0 MR0=0x18 MR4=0x1 MR5=0x1 MR8=0x10 MR12=0x72 MR14=0x72 MR18=0x0 MR19=0x0 MR24=0x8 MR25=0x0 channel 1 CS = 0 MR0=0x18 MR4=0x1 MR5=0x1 MR8=0x10 MR12=0x72 MR14=0x72 MR18=0x0 MR19=0x0 MR24=0x8 MR25=0x0 channel 0 training pass! channel 1 training pass! channel 0, cs 0, advanced training done channel 1, cs 0, advanced training done change freq to 856MHz 1,0 ch 0 ddrconfig = 0x101, ddrsize = 0x40 ch 1 ddrconfig = 0x101, ddrsize = 0x40 pmugrf_os_reg[2] = 0x32C1F2C1, stride = 0xD ddr_set_rate to 328MHZ ddr_set_rate to 666MHZ ddr_set_rate to 928MHZ channel 0, cs 0, advanced training done channel 1, cs 0, advanced training done ddr_set_rate to 416MHZ, ctl_index 0 ddr_set_rate to 856MHZ, ctl_index 1 support 416 856 328 666 928 MHz, current 856MHz OUT Boot1: 2019-03-14, version: 1.19 CPUId = 0x0 ChipType = 0x10, 254 mmc: ERROR: SDHCI ERR:cmd:0x102,stat:0x18000 mmc: ERROR: Card did not respond to voltage select! emmc reinit mmc: ERROR: SDHCI ERR:cmd:0x102,stat:0x18000 mmc: ERROR: Card did not respond to voltage select! emmc reinit mmc: ERROR: SDHCI ERR:cmd:0x102,stat:0x18000 mmc: ERROR: Card did not respond to voltage select! SdmmcInit=2 1 mmc0:cmd5,20 SdmmcInit=0 0 BootCapSize=0 UserCapSize=30436MB FwPartOffset=2000 , 0 StorageInit ok = 47527 SecureMode = 0 SecureInit read PBA: 0x4 SecureInit read PBA: 0x404 SecureInit read PBA: 0x804 SecureInit read PBA: 0xc04 SecureInit read PBA: 0x1004 SecureInit read PBA: 0x1404 SecureInit read PBA: 0x1804 SecureInit read PBA: 0x1c04 SecureInit ret = 0, SecureMode = 0 atags_set_bootdev: ret:(0) GPT 0x3380ec0 signature is wrong recovery gpt... GPT 0x3380ec0 signature is wrong recovery gpt fail! LoadTrust Addr:0x4000 No find bl30.bin No find bl32.bin Load uboot, ReadLba = 2000 hdr 0000000003380880 + 0x0:0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, Load OK, addr=0x200000, size=0xe5ba8 RunBL31 0x40000 NOTICE: BL31: v1.3(debug):42583b6 NOTICE: BL31: Built : 07:55:13, Oct 15 2019 NOTICE: BL31: Rockchip release version: v1.1 INFO: GICv3 with legacy support detected. ARM GICV3 driver initialized in EL3 INFO: Using opteed sec cpu_context! INFO: boot cpu mask: 0 INFO: plat_rockchip_pmu_init(1190): pd status 3e INFO: BL31: Initializing runtime services WARNING: No OPTEE provided by BL2 boot loader, Booting device without OPTEE initialization. SMC`s destined for OPTEE will return SMC_UNK ERROR: Error initializing runtime service opteed_fast INFO: BL31: Preparing for EL3 exit to normal world INFO: Entry point address = 0x200000 INFO: SPSR = 0x3c9 U-Boot 2020.10-armbian (Sep 08 2021 - 10:55:50 +0000) Edited September 11, 2023 by Gwen Lg 0 Quote Link to comment Share on other sites More sharing options...
