I am having a network problem that I can not figure out. First I had to roll back the kernel to version 5.x to even get wifi to work. Since then I have tried all sorts of things. No matter what I do, when I unplug the eth0 the wifi goes away as well. Here is some stuff that might help.
Version 1.1.1, based on Armbian 23.02.2 Bullseye
Running on OPi 3 LTS with Linux 5.15.93-sunxi64
System load: 41% Up time: 3 min
Memory usage: 15% of 1.94G IP: 192.168.1.161 192.168.1.160
CPU temp: 43°C Usage of /: 84% of 7.0G
[ Kernel and firmware upgrades disabled: armbian-config ]
Last check: 2023-09-16 20:53
Last login: Sat Sep 16 20:50:31 2023 from 192.168.1.65
pi@OrangePI3:~$ ip a
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 1000
link/ether 02:07:75:b2:b2:2d brd ff:ff:ff:ff:ff:ff
inet 192.168.1.161/24 brd 192.168.1.255 scope global eth0
3: wlan0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000
link/ether a0:ab:d6:c3:a7:66 brd ff:ff:ff:ff:ff:ff
inet 192.168.1.160/24 brd 192.168.1.255 scope global noprefixroute wlan0
You can post now and register later.
If you have an account, sign in now to post with your account.
Question
Kevin Bosworth
__ __ _ _ _ ____ _____
| \/ | (_) (_) |/ __ \ / ____|
| \ / | __ _ _ _ __ ___ __ _ _| | | | | (___
| |\/| |/ _` | | '_ \/ __|/ _` | | | | | |\___ \
| | | | (_| | | | | \__ \ (_| | | | |__| |____) |
|_| |_|\__,_|_|_| |_|___/\__,_|_|_|\____/|_____/
# armbian-config created
source /etc/network/interfaces.d/*
# Local loopback
auto lo
iface lo inet loopback
# Interface eth0
allow-hotplug eth0
iface eth0 inet static
address 192.168.1.161
netmask 255.255.255.0
gateway 192.168.1.1
dns-nameservers 192.168.1.1 8.8.8.8
I don't know what else to try. Thanks in advance.
Link to comment
Share on other sites
1 answer to this question
