Kevin Bosworth Posted September 17, 2023 Share Posted September 17, 2023 I am having a network problem that I can not figure out. First I had to roll back the kernel to version 5.x to even get wifi to work. Since then I have tried all sorts of things. No matter what I do, when I unplug the eth0 the wifi goes away as well. Here is some stuff that might help. __ __ _ _ _ ____ _____ | \/ | (_) (_) |/ __ \ / ____| | \ / | __ _ _ _ __ ___ __ _ _| | | | | (___ | |\/| |/ _` | | '_ \/ __|/ _` | | | | | |\___ \ | | | | (_| | | | | \__ \ (_| | | | |__| |____) | |_| |_|\__,_|_|_| |_|___/\__,_|_|_|\____/|_____/ Version 1.1.1, based on Armbian 23.02.2 Bullseye Running on OPi 3 LTS with Linux 5.15.93-sunxi64 System load: 41% Up time: 3 min Memory usage: 15% of 1.94G IP: 192.168.1.161 192.168.1.160 CPU temp: 43°C Usage of /: 84% of 7.0G [ Kernel and firmware upgrades disabled: armbian-config ] Last check: 2023-09-16 20:53 Last login: Sat Sep 16 20:50:31 2023 from 192.168.1.65 pi@OrangePI3:~$ ip a 1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000 link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00 inet 127.0.0.1/8 scope host lo valid_lft forever preferred_lft forever 2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 1000 link/ether 02:07:75:b2:b2:2d brd ff:ff:ff:ff:ff:ff inet 192.168.1.161/24 brd 192.168.1.255 scope global eth0 valid_lft forever preferred_lft forever 3: wlan0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000 link/ether a0:ab:d6:c3:a7:66 brd ff:ff:ff:ff:ff:ff inet 192.168.1.160/24 brd 192.168.1.255 scope global noprefixroute wlan0 valid_lft forever preferred_lft forever ------------------------------------------------------------------------------------------------------------------------------------------------------- # armbian-config created source /etc/network/interfaces.d/* # Local loopback auto lo iface lo inet loopback # Interface eth0 allow-hotplug eth0 iface eth0 inet static address 192.168.1.161 netmask 255.255.255.0 gateway 192.168.1.1 dns-nameservers 192.168.1.1 8.8.8.8 I don't know what else to try. Thanks in advance. 0 Quote Link to comment Share on other sites More sharing options...
Gunjan Gupta Posted September 18, 2023 Share Posted September 18, 2023 Could you please share the logs? Pull your ethernet out while wifi is working. Once the wifi stops working, plug the ethernet back in and run armbianmonitor -u to upload the logs. Then share the URL here. I have already created a PR to fix the wifi, it should get pulled in a few days. Then probably you can get the kernel from beta.armbian.com repository. But still I will try this out tomorrow on the newer kernel to see to make sure it doesn't have similar issue. 1 Quote Link to comment Share on other sites More sharing options...
