Basic IR setup on OPi3-lts
Go to solution Solved by usual user,
Hi all, I've just installed Armbian on my OPi3-lts and I'm trying to get the IR remote working (the iDroid included in the kit from aliexpress).
I've followed this guide (from "Second attempt" on), using only the kernel driver without intalling lirc.
Found out the protocol (nec), wrote the rc_keymap file mapping the key codes to the button names and everything seems to work fine, down to the last command (sudo ir-keytable -v -t -p nec), which correctly gives me the codes and the button names associated with them.
Now, the guide says it's all and I should be able to use the remote as I use my keyboard, but... the desktop and the apps seem not to be aware of it, since nothing happens when I press the buttons...
What am I missing?
Thank you in advance
Since you haven't provided any details about what keycodes you've mapped and what desktop features are assigned to them, no one can tell if what you're seeing is what to expect.
For now, I've only mapped the four arrow buttons in the remote to the four arrow keys: KEY_UP, KEY_LEFT, KEY_RIGHT and KEY_DOWN.
I'm in xfce. If I press the down arrow on my keyboard, the first icon in the desktop gets selected, and then I can move around using the arrow keys on the keyboard; however, pressing the arrow buttons on the remote has no effect.
Similarly, if I open the applications menu, I can navigate using the arrow keys on my keyboard, while pressing the arrow buttons on the remote has no effect.
This is what I mean.
I suspect the applications aren't getting the events?
Please tell me if you need more information, and which.
Thank you
WRONG OUTPUTS SORRY... please refer to next post
Ok, here they are.
ir-keytable:
Found /sys/class/rc/rc0/ with:
	Driver: sunxi-ir
	Default keymap: rc-empty
	Input device: /dev/input/event3
	LIRC device: /dev/lirc0
	Attached BPF protocols: Operazione non permessa
	Supported kernel protocols: lirc rc-5 rc-5-sz jvc sony nec sanyo mce_kbd rc-6 sharp xmp imon rc-mm
	Enabled kernel protocols: lirc
	bus: 25, vendor/product: 0001:0001, version: 0x0100
	Repeat delay = 500 ms, repeat period = 125 ms
ir-keytable -t doesn't print anything on button pressed
neither does ir-keytable -t -p nec, and it complains that it has no access to /sys/class/rc/rc0//protocols
however, sudo ir-keytable -t -p nec finally gives this output while pressing the buttons:
Protocols changed to nec
Testing events. Please, press CTRL-C to abort.
17366.585270: lirc protocol(nec): scancode = 0x444
17366.585303: event type EV_MSC(0x04): scancode = 0x444
17366.585303: event type EV_SYN(0x00).
17368.295701: lirc protocol(nec): scancode = 0x41c
17368.295735: event type EV_MSC(0x04): scancode = 0x41c
17368.295735: event type EV_SYN(0x00).
17369.768642: lirc protocol(nec): scancode = 0x448
17369.768688: event type EV_MSC(0x04): scancode = 0x448
17369.768688: event type EV_SYN(0x00).
17371.271205: lirc protocol(nec): scancode = 0x41d
17371.271237: event type EV_MSC(0x04): scancode = 0x41d
17371.271237: event type EV_SYN(0x00).
Thank you so much for helping!
Edited by tizianomattei
wrong outputs
SORRY, I forgot I had rebooted and lost my config.
Now I've redone the last steps and ir-keytable -t gives the following:
18634.316865: lirc protocol(nec): scancode = 0x41c
18634.316925: event type EV_MSC(0x04): scancode = 0x41c
18634.316925: event type EV_KEY(0x01) key_down: KEY_LEFT(0x0069)
18634.316925: event type EV_SYN(0x00).
18634.452052: event type EV_KEY(0x01) key_up: KEY_LEFT(0x0069)
18634.452052: event type EV_SYN(0x00).
18635.535743: lirc protocol(nec): scancode = 0x444
18635.535795: event type EV_MSC(0x04): scancode = 0x444
18635.535795: event type EV_KEY(0x01) key_down: KEY_UP(0x0067)
18635.535795: event type EV_SYN(0x00).
18635.668038: event type EV_KEY(0x01) key_up: KEY_UP(0x0067)
18635.668038: event type EV_SYN(0x00).
18636.345104: lirc protocol(nec): scancode = 0x448
18636.345149: event type EV_MSC(0x04): scancode = 0x448
18636.345149: event type EV_KEY(0x01) key_down: KEY_RIGHT(0x006a)
18636.345149: event type EV_SYN(0x00).
18636.480079: event type EV_KEY(0x01) key_up: KEY_RIGHT(0x006a)
18636.480079: event type EV_SYN(0x00).
18637.155758: lirc protocol(nec): scancode = 0x41d
18637.155803: event type EV_MSC(0x04): scancode = 0x41d
18637.155803: event type EV_KEY(0x01) key_down: KEY_DOWN(0x006c)
18637.155803: event type EV_SYN(0x00).
18637.288043: event type EV_KEY(0x01) key_up: KEY_DOWN(0x006c)
18637.288043: event type EV_SYN(0x00).
Anyway, the buttons still don't work in the desktop environment or the apps.
	Driver: sunxi-ir
	Enabled kernel protocols: lirc nec
This is ir-keytable without arguments...
  • Solution
I'm guessing you're configuring the rc only after XWindow is already started, that way the input event device can't be added as an XWindow input device at times.
Load the rc keymap during the boot process by adding it to /etc/rc_maps.cfg.
E.g.:
*       rc-empty                 your-config-name.toml
as last line added.
