piglet Posted September 19, 2023 Posted September 19, 2023 Hi, I have a board Orange Pi Zero with modified PAs for power of WiFi module from PA20 to PA02, by soldering a connection on board. This is done to allow connection of I2C DAC. I see that board definition in 'u-boot/configs/orangepi_zero_defconfig' It uses dts definition of: 'arch/arm/dts/sun8i-h2-plus-orangepi-zero.dts' I need to modify one section of this dts file from: reg_vcc_wifi: reg_vcc_wifi { compatible = "regulator-fixed"; regulator-min-microvolt = <3300000>; regulator-max-microvolt = <3300000>; regulator-name = "vcc-wifi"; enable-active-high; gpio = <&pio 0 20 GPIO_ACTIVE_HIGH>; to: reg_vcc_wifi: reg_vcc_wifi { compatible = "regulator-fixed"; regulator-min-microvolt = <3300000>; regulator-max-microvolt = <3300000>; regulator-name = "vcc-wifi"; enable-active-high; gpio = <&pio 0 2 GPIO_ACTIVE_HIGH>; How can I do this and use armbian build script: compile.sh Thanks, Michal 0 Quote
Gunjan Gupta Posted September 19, 2023 Posted September 19, 2023 There are two ways you can go. Either add a patch and build a new image. Or use official image with a device tree overlay to change that line. If you want to go the first route, run the following command ./compile.sh BOARD=orangepizero BRANCH=current uboot-patch It will start the patch mode and then wait for you to make changes. if you are building with docker, you have to open a shell using "docker exec -it <instance_id> /bin/bash". Go to cache/sources/u-boot-sunxi/<version>/ directory and make your changes. Go back to window where you ran ./compile.sh and press enter. It will ask you for few things once you provide those a patch file will be created in output directory. Then you can copy that patch file to patch/u-boot/u-boot-sunxi directory so that the patch applies to the image you have to do the same thing for kernel as well. Most of the workflow will remain the same just command will be kernel-patch instead of uboot-patch and source directory will also be something like cache/sources/linux-something. The patch has to be placed in patch/kernel/archive/sunxi-<kernel_version>/ directory or its corresponding userpatches directory. If you go to device tree overlay route, create a file called sun8i-h3-reg_vcc_wifi.dts with the following content /dts-v1/; /plugin/; ®_vcc_wifi { gpio = <&pio 0 2 GPIO_ACTIVE_HIGH>; }; compile it with "dtc -@ -I dts -O dtb -o sun8i-h3-reg_vcc_wifi.dtb sun8i-h3-reg_vcc_wifi.dts". copy dtb file to /boot/dtb/overlays directory and enable it using armbian-config. It will take affect after reboot 0 Quote
piglet Posted October 6, 2023 Author Posted October 6, 2023 (edited) Thank you for this information. I still struggle to get it working. a. First approach - patch of uboot and kernel Effect I see: modules of wifi are loaded. lsmod returns: xradio_wlan 118784 0 mac80211 606208 1 xradio_wlan cfg80211 573440 2 mac80211,xradio_wlan However eth1 for wifi is not created. I couldn't spot what is missing. b. Second approach - dtb overlay It seems to be a simpler solution. I wasn't able to compile proposed file. It shows an error on 'gpio...' line I tried to add #include lines from the original board dts file but with no success. I would prefer to use an overlay as it is simpler and quicker. Any suggestions? Thanks, Michal Edited October 6, 2023 by piglet 0 Quote
Gunjan Gupta Posted October 6, 2023 Posted October 6, 2023 try replacing GPIO_ACTIVE_HIGH with 0. That will remove need of the including header files. In case you still face compilation issue, please share the output of dtc command 0 Quote
piglet Posted October 19, 2023 Author Posted October 19, 2023 Thank you very much for help. The overlay approach is really simple to use. The file that worked is following: /dts-v1/; /plugin/; / { compatible = "allwinner,sun8i-h3"; fragment@0 { target = <®_vcc_wifi>; __overlay__ { gpio = <&pio 0 2 1>; }; }; }; I saved it to a file: sun8i-h3-reg_vcc_wifi.dts Than I added it as an overlay using command armbian-add-overlay sun8i-h3-reg_vcc_wifi.dts After reboot it was working. This was done on: - Orange Pi Zero with soldered connection for wifi supply from another pin - Armbian 23.11.0 6.1.56-current-sunxi 0 Quote
Fiery_Fire Posted September 19 Posted September 19 Hi @Gunjan Gupta, Thanks for the info. I'm trying to do something similar but on a different board. Running the "uboot-patch" build command just seems to download uboot?? There is no pause for me to make changes then to hit enter to continue. Has the process changed or am I doing something wrong? Many Thanks, Fiery 0 Quote
The Tall Man Posted September 20 Posted September 20 (edited) I recently had to modify a device tree file for a different reason. I showed what I did (and how I did it) here: https://forum.armbian.com/topic/52118-hdmi-audio-and-analog-audio-do-not-work-on-opi5plus/?do=findComment&comment=224923 To summarize, I used the device-tree-compiler package (command line: dtc) to convert the device tree binary (.dtb) file to a device tree source (.dts) file. Then I edited the .dts file, then converted it back. The process won't show you all the variable names, but the resulting .dts is readable enough to likely see what and where you need to change... and even moreso if you have the original (pre-compiled) .dts file to compare it with. If you need to match variable names with specific numbers, they will likely be #defined in the #includes at the top of the original .dts file. Edited September 20 by The Tall Man 0 Quote
