Enable 3D Acceleration on bullseye legacy
Go to solution Solved by Miguel González,
Hello everyone, I have been searching on the net trying to find a way to activate 3d acceleration since i want to use Jellyfin on my orange pi 5. After searching I found the option for ubuntu but not for bullseye, unfortunately I'm using bullseye due to OMV which won't work on ubuntu to use for my media server. Is there any way to turn on the 3d acceleration on Debian? I mean it should be possible since technically Ubuntu is based on Debian. but i was wondering if there are any steps that I need to follow.
  • Solution
Unfortunately I have only found this way to obtain the necessary driver that Liu Jiang Feng made for ubuntu but on Debian, its not perfect since you cant update it like any regular file, but it appears to be working.
sudo apt install devscripts build-essential equivs v4l-utils
if necessary for installing v4l-utils due to error
sudo apt --fix-broken install
dget --extract --allow-unauthenticated https://launchpad.net/~liujianfeng1994/+archive/ubuntu/panfork-mesa/+files/mali-g610-firmware_1.0.2_source.changes
ignore curl(22) 404 error
cd mali-g610-firmware-1.0.2
sudo mk-build-deps --install --remove
dpkg-buildpackage --build=binary --no-sign
cd
sudo dpkg -i mali-g610-firmware_1.0.2_all.deb
dget --extract --allow-unauthenticated https://launchpad.net/~liujianfeng1994/+archive/ubuntu/rockchip-multimedia/+files/rockchip-multimedia-config_1.0.0-3+jammy_source.changes
cd rockchip-multimedia-config-1.0.0
cd
sudo dpkg -i rockchip-multimedia-config_1.0.0-3+jammy_all.deb
