Question to experts in linux
I wrote a program© that directly draws / writes to framebuffor /dev/fb0
 (LCD connected to the HDMI - Shows graphic reading temeperature DS1820, actual clock etc)
What to do to disable writing to the same buffor by the system?
Thanks
Not an expert or even close...
But ...
I thought the whole point of the driver/controller model is to manage resource contention in userspace.
otherwise everyone would just map registers into their virtual memory and have at it.
Which I guess is the argument for userspace drivers when that is appropriate and don't risk crashing your kernel etc.
So if your using a driver to update a fb it should be safe.
I'm guessing youve gone here but putting it out there incase..
https://www.kernel.org/doc/Documentation/fb/
The Linux driver/controller arena could definitely be more understandable.
