RSS Bot Posted October 16, 2023 Posted October 16, 2023 Description I have changed the way the patches are generated a bit. Instead of using orange-pi branch from megous tree for 6.6 kernel, I have used the following 6.6 kernel branches from megous tree a83t-suspend, af8133j, anx, audio, axp, cam, err, fixes, mbus, modem, opi3, pb, pinetab, pp, ppkb, samuel, speed, tbs-a711, ths These branches were carefully chosen to include only allwinner related patches and remove importing of most of the rockchip related patches into the allwinner kernel. This has led to decrease in the total applied patch count by 84. We now apply 407 patches instead of 491 patches as applied in 6.5 kernel, while all functionality will remain the same. Following patches are modified to fix patch application failure patches.armbian/arm64-dts-sun50i-h616-orangepi-zero2-reg_usb1_vbus-status-ok.patch patches.armbian/arm64-dts-sun50i-h616-orangepi-zero2-Enable-GPU-mali.patch patches.armbian/arm64-dts-allwinner-h616-Add-efuse_xlate-cpu-frequency-scaling-v1_6_2.patch patches.armbian/arm64-dts-allwinner-h616-LED-green_power_on-red_status_heartbeat.patch patches.armbian/arm64-dts-allwinner-overlay-Add-Overlays-for-sunxi64.patch patches.armbian/arm64-dts-sun50i-h616-bigtreetech-cb1.patch Following patches are modified because of kernel api change to fix compilation failure patches.armbian/drv-gpu-drm-sun4i-Add-HDMI-audio-sun4i-hdmi-encoder.patch patches.armbian/drv-of-Device-Tree-Overlay-ConfigFS-interface.patch All patches are rebased using rewrite-kernel-patches and kernel config is rebased using rewrite-kernel-config commands How Has This Been Tested? Please describe the tests that you ran to verify your changes. Please also note any relevant details for your test configuration. [ ] Both sunxi and sunxi64 edge kernel compiles fine. On device testing is still work in progress Checklist: [ ] My code follows the style guidelines of this project [ ] I have performed a self-review of my own code [ ] I have commented my code, particularly in hard-to-understand areas [ ] I have made corresponding changes to the documentation [X] My changes generate no new warnings [ ] Any dependent changes have been merged and published in downstream modules View the full article
