USB2 speed when using Top USB3 port with a SATA SSD in a USB3 enclosure with UASP
Posted (edited)
*UPDATED - The issue is the powered USB3 hub which is actually NOT USB3 as advertised and is instead USB2. Sorry to have wasted your time*
Hi,
I have a 1TB SATA SSD in a USB3 enclosure (that supports UASP) connected to a USB3 powered hub, which in turn connects to the Top USB3 port of an Orange Pi 5 4GB.  Armbian (Debian Bookworm) is installed and running from a 128GB NVME drive plugged into the M2 slot of the Orange Pi 5.
If I do an "lsusb -t" I get the output shown below. The SSD is Bus 02, Port 3, Dev 5 and is using the uas driver but is showing USB2 speed of 480M rather than USB3 speed of 5000M.
I have also tried plugging the powered USB3 hub with SATA SSD USB3 enclosure plugged into the USB C data port but I have the same limitation.
I have plugged the SATA SSD USB3 enclosure into my intel file server running Debian Bookworm and it uses the uas driver at 5000M with no issues.
Am I doing something wrong? Do I need to disable the USB C port or dual hdmi display output for this to work? (I only use the HDMI port for video output) and have nothing connected to the USB C data port.
Thanks in advance for any help and guidance on this.
/:  Bus 08.Port 1: Dev 1, Class=root_hub, Driver=xhci-hcd/1p, 5000M
/:  Bus 07.Port 1: Dev 1, Class=root_hub, Driver=xhci-hcd/1p, 480M
/:  Bus 06.Port 1: Dev 1, Class=root_hub, Driver=xhci-hcd/1p, 5000M
/:  Bus 05.Port 1: Dev 1, Class=root_hub, Driver=xhci-hcd/1p, 480M
/:  Bus 04.Port 1: Dev 1, Class=root_hub, Driver=ohci-platform/1p, 12M
/:  Bus 03.Port 1: Dev 1, Class=root_hub, Driver=ohci-platform/1p, 12M
/:  Bus 02.Port 1: Dev 1, Class=root_hub, Driver=ehci-platform/1p, 480M
    |__ Port 1: Dev 2, If 0, Class=Hub, Driver=hub/4p, 480M
        |__ Port 1: Dev 7, If 0, Class=Vendor Specific Class, Driver=xpad, 12M
        |__ Port 2: Dev 4, If 0, Class=Human Interface Device, Driver=usbhid, 12M
        |__ Port 2: Dev 4, If 1, Class=Human Interface Device, Driver=usbhid, 12M
        |__ Port 2: Dev 4, If 2, Class=Human Interface Device, Driver=usbhid, 12M
        |__ Port 2: Dev 4, If 3, Class=Human Interface Device, Driver=usbhid, 12M
        |__ Port 2: Dev 4, If 4, Class=Human Interface Device, Driver=usbhid, 12M
        |__ Port 3: Dev 5, If 0, Class=Mass Storage, Driver=uas, 480M
        |__ Port 4: Dev 6, If 3, Class=Application Specific Interface, Driver=, 12M
        |__ Port 4: Dev 6, If 1, Class=Vendor Specific Class, Driver=btusb, 12M
        |__ Port 4: Dev 6, If 2, Class=Vendor Specific Class, Driver=btusb, 12M
        |__ Port 4: Dev 6, If 0, Class=Vendor Specific Class, Driver=btusb, 12M
/:  Bus 01.Port 1: Dev 1, Class=root_hub, Driver=ehci-platform/1p, 480M
Edited by adr3nal1n27
Issue is not with Armbian but with USB enclosure
