So I'm pretty new at using serial ports in linux so not even sure if this is the right place.
I'm playing around with MIDI using the serial ports on the Orange PiLite - it uses the baud rate of 31250 to achieve this you use setserial to get the base_baud (which it reports as 1500000) and you divide by the speed you want to get the divisor
i.e. 1500000/31250 = 48
this becomes
>setserial /dev/ttyS1 divisor 48 speed_cust
So now when you use 38400 as your baud speed it actually becomes 31250....
...in theory
after some fiddling I found the divsor is actually 50 as 48 gives you weird results
which would suggest that the base_baud is actually 1562500 not 1500000
So where is this initial base_baud set?
I assuming in the kernel?
I see this:
sources/u-boot/v2016.11/include/configs/rk3399_common.h:16:#define CONFIG_BAUDRATE 1500000
But i really don't know if this is correct :)
Edit: oops I put spaces in setserial
Edited by Starfishmod
