RSS Bot Posted November 12, 2023 Share Posted November 12, 2023 rk3588: experimental UEFI edk2 support core extensions: fix: don't redefine extension_function_info when recursing otherwise when there's a chain of enable_extension() we lose the original info extensions: grub-with-dtb: add UMS menu entry to GRUB if initramfs ums hook is detected this allows user to enter UMS mode from GRUB for usage with the initramfs-usb-gadget-ums extension has no effect unless initramfs-usb-gadget-ums extension is enabled together with grub-with-dtb extensions: initramfs-usb-gadget-ums: kernel cmdline enables initramfs UMS of all block devices this optional extension adds an initramfs script that: enumerates and filters all block devices exposes each device as an UMS (USB Mass Storage) in an USB Gadget loops forever with info (board never boots) the idea here is to compensate for UEFI's lack of "ums" or "rockusb" mode that's present in u-boot it also allows to expose USB/NVMe devices that might or not be detected by bootloader, if the kernel works extensions: uefi-edk2-rk3588: deploy edk2 (not u-boot) for rk3588 boards this extension is 100% optional and shouldn't adversely affect any builds if not enabled requires UEFI_EDK2_BOARD_ID to be set in board file, so we know which UEFI/edk2 build to use it finds the latest edk2 version from GitHub automatically (currently v0.9.1) it downloads (and caches) the correct edk2 build image automatically if forces certain aspects of the image: must use GPT partitioning must NOT use a separate /boot partition it disables the building and deploying of u-boot completely (thus blobs etc are from edk2) it creates a GPT "uboot" partition pointing to edk2's FIT, required by SPL this extension: automatically enables 'grub-with-dtb' automatically enable 'initramfs-usb-gadget-ums', to compensate for lack of ums/rockusb since we dont have u-boot anymore rk3588: configure UEFI_EDK2_BOARD_ID for all UEFI-supported boards From https://github.com/edk2-porting/edk2-rk3588/releases/tag/v0.9.1 For example, for rock-5b_UEFI_Release_v0.9.1.img UEFI_EDK2_BOARD_ID is rock-5b Important: this has no effect unless optional extension is enabled to test this out: make sure to read carefully the instructions at https://github.com/edk2-porting/edk2-rk3588/blob/master/README.md suppose you previously built the regular u-boot version with: ./compile.sh BOARD=rock-5b BRANCH=legacy RELEASE=jammy now you can build the UEFI version with: ./compile.sh BOARD=rock-5b BRANCH=legacy RELEASE=jammy EXT=uefi-edk2-rk3588 write the produced image to SD or eMMC and boot it use normally, or enter "UMS" mode by selecting that option in the grub menu You can write image to eMMC, boot it, enter UMS, write it again to NVMe, reboot, press in UEFI and boot from NVMe Also works if .img is written to eg USB stick, and UEFI edk2 is separately deployed to SPI flash Important: make absolutely sure you are able to force Maskrom mode (by shorting pins, pressing buttons, etc) before writing an UEFI image to eMMC; UEFI has no RockUSB ("Loader mode" support) at all. The new "initramfs-usb-gadget-ums" extension hopes to address this, but it is not guaranteed to work. View the full article Link to comment Share on other sites More sharing options...
