Guest Posted November 14, 2023 Posted November 14, 2023 (edited) when I tried to install Armbian (Armbian_23.8.1_Lepotato_bookworm_current_6.1.50.img.xz) on my Le Potato, it asked me to enter the desired value of the TZ environment variable when I chose not to set the timezone automatically. however I am confused with what is a valid Posix timezone string. here are my attempts: Please enter the desired value of the TZ environment variable. For example, AEST-10 is abbreviated AEST and is 10 hours ahead (east) of Greenwich, with no daylight saving time. UTC 'UTC' is not a conforming Posix timezone string. Please enter the desired value of the TZ environment variable. For example, AEST-10 is abbreviated AEST and is 10 hours ahead (east) of Greenwich, with no daylight saving time. UTC-0 'UTC-0' is not a conforming Posix timezone string. Please enter the desired value of the TZ environment variable. For example, AEST-10 is abbreviated AEST and is 10 hours ahead (east) of Greenwich, with no daylight saving time. GMT 'GMT' is not a conforming Posix timezone string. Please enter the desired value of the TZ environment variable. For example, AEST-10 is abbreviated AEST and is 10 hours ahead (east) of Greenwich, with no daylight saving time. GMT-0 'GMT-0' is not a conforming Posix timezone string. Please enter the desired value of the TZ environment variable. For example, AEST-10 is abbreviated AEST and is 10 hours ahead (east) of Greenwich, with no daylight saving time. Etc/UTC 'Etc/UTC' is not a conforming Posix timezone string. Please enter the desired value of the TZ environment variable. For example, AEST-10 is abbreviated AEST and is 10 hours ahead (east) of Greenwich, with no daylight saving time. AEST-10 'AEST-10' is not a conforming Posix timezone string. Edited November 14, 2023 by CocoNut typo 0 Quote
c0rnelius Posted November 14, 2023 Posted November 14, 2023 `sudo dpkg-reconfigure tzdata` doesn't work for you? 0 Quote
Guest Posted August 24, 2024 Posted August 24, 2024 (edited) For anyone who had the same kind of issues, 'UTC-0' worked for me. Edited August 24, 2024 by Guest typo 0 Quote
kris777 Posted September 8, 2024 Posted September 8, 2024 (edited) I had problems with the update: apt update supposedly it was a problem with time. helped: sudo apt-get install ntpdate sudo ntpdate pool.ntp.org and I tried before the entry :upade apt-get -o Acquire::Check-Valid-Until=false -o Acquire::Check-Date=false update but I had another problem with the reboot option which didn't always work? And also restarting the Pi-3 LTS after the poweroff option from the button on the case for 2 seconds. I switched to FW from the Orange PI provider: Orangepi3-lts_3.0.8_debian_bullseye_server_linux5.16.17 and now it's OK? Edited September 8, 2024 by kris777 0 Quote
Darth-Echo Posted December 8, 2024 Posted December 8, 2024 I am having the exact same issue with Armbian 24.11.1 Bookworm. Just like the original post, the OS isn't even recognizing its own example. I'm stuck. I can't go back and choose something else. I can't skip. I can't report this as a bug since it is happening during setup. 'EST5EDT,M3.2.0/2,M11.1.0/2' is not a conforming Posix timezone string. Please enter the desired value of the TZ environment variable. For example, AEST-10 is abbreviated AEST and is 10 hours ahead (east) of Greenwich, with no daylight savings. 'EST-5EDT' is not a conforming Posix timezone string. Please enter the desired value of the TZ environment variable. For example, AEST-10 is abbreviated AEST and is 10 hours ahead (east) of Greenwich, with no daylight savings. 'EST5EDT' is not a conforming Posix timezone string. Please enter the desired value of the TZ environment variable. For example, AEST-10 is abbreviated AEST and is 10 hours ahead (east) of Greenwich, with no daylight savings. 'EST-5' is not a conforming Posix timezone string. Please enter the desired value of the TZ environment variable. For example, AEST-10 is abbreviated AEST and is 10 hours ahead (east) of Greenwich, with no daylight savings. 'UTC-0' is not a conforming Posix timezone string. Please enter the desired value of the TZ environment variable. For example, AEST-10 is abbreviated AEST and is 10 hours ahead (east) of Greenwich, with no daylight savings. 'AEST-10' is not a conforming Posix timezone string. Please enter the desired value of the TZ environment variable. For example, AEST-10 is abbreviated AEST and is 10 hours ahead (east) of Greenwich, with no daylight savings. 'UTC' is not a conforming Posix timezone string. Please enter the desired value of the TZ environment variable. For example, AEST-10 is abbreviated AEST and is 10 hours ahead (east) of Greenwich, with no daylight savings. 'EST' is not a conforming Posix timezone string. Please enter the desired value of the TZ environment variable. For example, AEST-10 is abbreviated AEST and is 10 hours ahead (east) of Greenwich, with no daylight savings. ' ' is not a conforming Posix timezone string. Please enter the desired value of the TZ environment variable. For example, AEST-10 is abbreviated AEST and is 10 hours ahead (east) of Greenwich, with no daylight savings. 0 Quote
eewe32 Posted May 24, 2025 Posted May 24, 2025 chatgpt advised to type ":UTC" or ":Europe/Berlin" and it helped. 1 Quote
samtab10.2000 Posted June 1, 2025 Posted June 1, 2025 my current timezone is PST (suppose to be PH starndard time) configured via raspi-config, im guessing it is confusing itself with PST (Pacific standard time US). it really messing with my TZ. For my part the only workaround is to set it manually before i can upgrade the system $ TZ=':UTC'; export TZ 0 Quote
