Hi there,
ย
I have a working armbian jammy on my odroid c2, but I'm unable to get SPI to work. I tried to load the three as described in the odroid wiki (https://wiki.odroid.com/odroid-xu4/application_note/gpio/spi#tab__odroid-c2๐Ÿ˜ž
ย
sudo modprobe spidev
sudo modprobe spi_gpio
sudo modprobe spi_bitbang
ย
...and that works, but unfortunately no device file is created.
ย
I believe SPI needs to be enabled somewhere additonally. In the "armbian-config" hardware section, there is only an entry for the odroid n2, which does not help/work for me.
ย
Are there any other hints somebody can give me to make it work?
ย
thanks a lot!
sg
Seems like it needs also be enabled in the armbian-config hardware-section, but unfortunately, there is no appropriate entry for the C2. ๐Ÿ˜ž
ร—
ร—
