no shutdown cubietruck with li-battery
luca219
hi all,
I tried in various forums, but without an effective solution.
I use cubieboard3 with cubietruck
Linux cubietruck 3.4.104-sunxi #1 SMP PREEMPT Fri Oct 17 16:13:30 CEST 2014 armv7l GNU/Linux
Debian GNU/Linux 7 \n \l
When i run poweroff or shutdown -H or other option the system reboots instead of shutting down.
 ls -la /sbin/poweroff
lrwxrwxrwx 1 root root 4 jul 18  2013 /sbin/poweroff -> halt
if unplug li-battery shutdown work fine.
Does anyone have any suggestions?
regards
Link to comment
Share on other sites
hi all,
regards
Hi, luca219!
This is a known bug on the image with the kernel 3.4.x.
There is no bug in the image with the new kernel 4.2.3
Link to comment
On OrangePi mini I must to do as root:
first convert bin to fex file:
bin2fex /boot/bin/orangepi.bin /root/orangepi.fex
edit with nano orangepi.fex
and include on [target] section:
power_start = 1
after convert it to bin:
fex2bin /root/orangepi.bin /boot/bin/orangepi.bin
and reboot
Link to comment
great!!   problem solved!!
step for cubietruck and cubieboard3
[root@hosts]# bin2fex /boot/cubietruck.bin /root/cubietruck.fex
fexc-bin: /boot/cubietruck.bin: version: 0.1.2
fexc-bin: /boot/cubietruck.bin: size: 46240 (83 sections)
[root@hosts]# nano /root/cubietruck.fex
power_start = 1
make backup
[root@hosts]# cp /boot/cubietruck.bin /boot/cubietruck.binori
[root@hosts]# fex2bin /root/cubietruck.fex /boot/cubietruck.bin
reboot
shutdown now work!!
Thank you :thumbup:
Link to comment
