I'm trying to generate an Armbian image for a custom board. I generated configuration files for card and family, with the necessary information for u-boot and kernel. I need to have separate boot partition in FAT and I added BOOTFS_TYPE="fat".
Using the compile.sh in the Armbian "build" repo I get an image, but flashing it on the sdcard does not start uboot. In the boot partition I find not only the kernel and dtb, but also the u-boot scripts. How do you generate an image that contains everything correctly?
Thanks in advance
Riccardo
Thats correct
Didn't you yourself said that you need seperate boot partition? That means everything else is in root partition. What else were you expecting to be in boot partition?
The post has zero information about the soc you are targetting, changes that you made and output you got on serial console when you tried booting. I don't think anyone can help you without getting that information
Thanks  Gunjan
I probably made some errors in board configuration file and I am troubleshooting.
8 hours ago, Gunjan Gupta said:
Thats correct
This make me have a fat16 partition, and with correct configuration I was able to get a bootable partition with ID 0e: is it possible to make a fat32 partition to obtain a "0c" partition? (I am referring to https://en.wikipedia.org/wiki/Partition_type), the only difference between the types is fat16/fat32 an for my system fat32 is better
thanks again
Riccardo
