Max Safronov Posted December 14, 2023 Posted December 14, 2023 Hi guys. I'm just wondering if I can install Linux on it. STB in DEVELOPER mode, I can connect ADB and I see some stuff here: vip6102w:/ $ df -h Filesystem Size Used Avail Use% Mounted on /dev/root 1.9G 917M 1.0G 47% / tmpfs 822M 492K 821M 1% /dev tmpfs 822M 112K 822M 1% /mnt /dev/block/dm-1 488M 77M 401M 17% /vendor /dev/block/mmcblk1p22 8.8G 1.4G 7.2G 17% /data /dev/block/mmcblk1p8 0.9M 34K 970K 4% /dev/hwcfg /dev/block/mmcblk1p15 5.6M 120K 5.2M 3% /cache /data/media 8.8G 1.4G 7.2G 17% /storage/emulated vip6102w:/ $ uname -a Linux localhost 4.9.208-1-6pre #1 SMP Fri Aug 28 15:30:05 PDT 2020 armv7l 127|vip6102w:/ $ sudo /system/bin/sh: sudo: not found vip6102w:/ $ ls ls: ./init: Permission denied ls: ./metadata: Permission denied ls: ./postinstall: Permission denied acct d init.environ.rc init.usb.configfs.rc oem storage bin data init.rc init.usb.rc proc sys bugreports default.prop init.recovery.block.rc init.zygote32.rc product system cache dev init.recovery.usb.rc lost+found res ueventd.rc charger eio init.recovery.vip6102w.rc mnt sbin vendor config etc init.recovery.wificfg.rc odm sdcard verity_key 0 Quote
Max Safronov Posted December 14, 2023 Author Posted December 14, 2023 Arris VIP6102W - UHD, IP • PPage SoC: Broadcom BCM7271 (Quad-core), 15000 DMIPS RAM: 2GB DDR4; Storage: 8GB eMMC Flash Wi-Fi: 4x4 802.11ac 0 Quote
Hqnicolas Posted January 9, 2025 Posted January 9, 2025 (edited) This device arrived in my country, https://www.commscope.com/globalassets/digizuite/286462-p360-vip6102w-external.pdf The factory is reliable, they have a long history in telecom but 4x ARM CORTEX-A53 you could find in any 18U$ TV box https://device.report/m/e21439a73965ba9f6545bed4078a8f60946acf19ca8edd1e3684848f443b0ce8.pdf Edited January 9, 2025 by Hqnicolas 0 Quote
