rix81 Posted December 29, 2023 Posted December 29, 2023 (edited) Hello, i'm using Armbian 23.11 Jammy-amazingfated Gnome. Kernel 5.10 If to seek a couple of times in h264 1080p BD remux'es it will cause system restart. Any video players are affected. Tried mpv, vlc, kodi and others. Problem affect just h264 1080p remuxes, that typically are 30..40 Gb, smaller h264 or even larger h265 files seem to work fine. I tried fresh install of armbian, where no rkmpp is installed, then h264 files plays/seeks fine, in software mode of course. Once I did sudo update/upgrade, that also installs rkmpp and other rockchip stuff, then videos start to play with rkmpp and problem is back. I've tried disabling hw decoding as workaround , weird, but it seems it's not possible to do in any player. In mpv : hwdec=no , or pressing ctrl+h has no affect, can't get rid of rkmpp decoder. Ive tried all possible commands related to this, from official mpv documentation, but nothing helps to disable rkmpp . This is probably another issue. Disabling buggy h264_rkmpp_decoder could be good workaround, as cpu is easily capable do play 1080p in sw, but can't find a way to do this, no matter i try, pls help. Especially looking for solution for mpv Edited December 30, 2023 by rix81 0 Quote
amazingfate Posted December 30, 2023 Posted December 30, 2023 Mpv doesn't controll rkmpp by hwdec. It just get what ffmpeg gives. You can set sw decoder by ffplay: ffplay -vcodec h264 test.mp4 0 Quote
rix81 Posted December 30, 2023 Author Posted December 30, 2023 (edited) 14 hours ago, amazingfate said: ffplay -vcodec h264 test.mp4 Thanks, it plays/seeks perfectly fine, with no issues. Is there something I can do to disable h264 hw decoder in mpv/ffmpeg ? it's really buggy... other from system restarts, it may hang up system sometimes, e.g. when closing player Edited December 31, 2023 by rix81 0 Quote
rix81 Posted January 1, 2024 Author Posted January 1, 2024 (edited) I've compiled/installed ffmpeg using this guide And problem with seek is gone ! I'm newbie in linux, don't know how good is this solution. Will this compiled version be overwritten by one from ppa on updates? Edited January 1, 2024 by rix81 0 Quote
noba Posted March 13, 2024 Posted March 13, 2024 Thank you so much rix81 and amazingfate, I also had this issue and fixed it by compiling ffmpeg using the guide linked above! I'm also new at this, but i installed it using checkinstall to prevent apt overwriting it, and that seems to be working for me! 0 Quote
