schunckt Posted January 2, 2024 Posted January 2, 2024 Hi all! I may need some pointers. I'm using a 2.4" LCD at spi1 which works as /dev/fb0 on armbian bookworm (6.1.63) Meanwhile I've learned frambuffer is deprecated and to be replaced by drm., but ... - I could not find enough details to understand the drm architecture in general - there is a linux/drivers/gpu/drm/tiny/ili9341.c how is that used at all? - How to use drm in armbian? For my case any acceleration is not necessary (and likely not possible even if the H3 has Mali Hardware) but I want to avoid further changes if /fbX is really gone. btw. I want to add touch with shared SPI soon, work in progress. Of course that should also work then later on with drm - I'm thinking of any possible conflicts inside the Device Tree which then may need further tweaking. It's all nice but sooooooo time consuming... T. 0 Quote
