bschwand Posted January 9, 2024 Posted January 9, 2024 a device hooked up on the microusb OTG port does not power up anymore (webcam, used to work a long time ago then I did system update but did not configure the webcam again, until now...) bruno@orangepione:~$ sudo cat /sys/kernel/debug/gpio [sudo] password for bruno: gpiochip0: GPIOs 0-223, parent: platform/1c20800.pinctrl, 1c20800.pinctrl: gpio-15 ( |orangepi:red:status ) out lo gpio-166 ( |cd ) in lo ACTIVE LOW gpio-204 ( |usb0_id_det ) in lo IRQ gpiochip1: GPIOs 352-383, parent: platform/1f02c00.pinctrl, 1f02c00.pinctrl: gpio-354 ( |usb0-vbus ) out lo gpio-355 ( |sw4 ) in hi IRQ ACTIVE LOW gpio-358 ( |vdd-cpux ) out hi gpio-362 ( |orangepi:green:pwr ) out hi Looks like no power on usb0, which should be enabled in host mode I enabled in armbian-config hardware configuration usbhost 0 to 4 (shows in armbianEnv.txt ) I edited sun8i-h3-orangepi-one.dtb so that usb0 dr_mode is set to "host" (like shown here https://forum.armbian.com/topic/4814-orange-pi-one-usb-otg/?do=findComment&comment=44756 ) I perused this thread https://forum.armbian.com/topic/8686-orange-pi-lite-using-micro-usb-otg-as-host-for-usb-camera/ and verified handles and setting seem to match. Seems no matter what, usb0 is not powered. What am I missing ? Any help greatly appreciated... sun8i-h3-orangepi-one.dtbFetching info... sun8i-h3-orangepi-one.dtsFetching info... 0 Quote
Gunjan Gupta Posted January 9, 2024 Posted January 9, 2024 with no logs shared, there is nothing that we can use to figure out what might be the issue. Upload logs using armbianmonitor -u and share the link here 0 Quote
bschwand Posted January 9, 2024 Author Posted January 9, 2024 (edited) armbianmonitor can not upload for whatever reason so here is the output from armbianmonitor -U armbianmonitor.logFetching info... bruno@orangepione:~$ less /boot/armbianEnv.txt verbosity=1 bootlogo=false console=both disp_mode=1920x1080p60 overlay_prefix=sun8i-h3 rootdev=UUID=2f506a90-a24d-4930-a5bb-8d61ce45629a rootfstype=ext4 overlays=usbhost0 usbhost1 usbhost2 usbhost3 usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u Edited January 9, 2024 by bschwand 0 Quote
Gunjan Gupta Posted January 9, 2024 Posted January 9, 2024 You are using a very old release. Please upgrade to latest image if possible. USB should work fine in 23.11 image. 0 Quote
bschwand Posted January 11, 2024 Author Posted January 11, 2024 I don't understand, I did a system update/upgrade with armbian-config before posting here. so I thought I was running latest version already. ok so now I just ran directly from CLI: sudo apt update sudo apt upgrade bruno@orangepione:~$ uname -a Linux orangepione 6.4.12-edge-sunxi #2 SMP Wed Aug 23 15:32:56 UTC 2023 armv7l armv7l armv7l GNU/Linux and my usbhost is indeed powering up. dang, that was silly... thanks for pointing out my system was far out of date. Thanks and cheers ! 0 Quote
