Share your Raspberry pi4b wifi through ethernet - turns your rp4b into wifi dongle for all your boards through eth0
Posted (edited)
Sharing is caring.
Did finally manage to get this working.   So lets make it simple clever.
Actually i did this on a 64bit raspian light kernel 6.1 but it must be the same on Armbian
10 jan 24
    Sharing the Raspberry Pi's WiFi over the ethernet port
sudo apt get update && sudo apt install dnsmasq iptables iptables-persistent dhcpcd5
sudo vim /etc/dhcpcd.conf
    interface eth0
    static ip_address=192.168.4.1/24
sudo mv /etc/dnsmasq.conf /etc/dnsmasq.conf.bk
sudo nano /etc/dnsmasq.conf -
 interface=eth0
dhcp-range=192.168.4.8,192.168.4.250,255.255.255.0,12h
server=8.8.8.8
bogus-priv
sudo systemctl restart dnsmasq.service
sudo vim /etc/sysctl.conf
    net.ipv4.ip_forward=1
sudo systemctl start dnsmasq
sudo sh -c "echo 1 > /proc/sys/net/ipv4/ip_forward"
sudo iptables -t nat -A POSTROUTING -o wlan0 -j MASQUERADE
sudo iptables -A FORWARD -i wlan0 -o eth0 -m state --state RELATED,ESTABLISHED -j ACCEPT
sudo iptables -A FORWARD -i eth0 -o wlan0 -j ACCEPT
sudo iptables -L -n -v
sudo sh -c "iptables-save > /etc/iptables.ipv4.nat"
sudo vim /etc/rc.local
    iptables-restore < /etc/iptables.ipv4.nat
exit0
sudo reboot
Did get a perfect internet connection on odroid n2+ through eth0 - so the rpi4b is now supplying wifi for that board and providing petitboot with netbooting images through netboot_default after exit to shell.
Edited by denni_isl
  • denni_isl changed the title to Share your Raspberry pi4b wifi through ethernet - turns your rp4b into wifi dongle for all your boards through eth0
Posted (edited)
This is in /etc/dnsmasq.conf
interface=eth0
# listen=192.168.4.1
 server=8.8.8.8
# domain-deeded
 bogus-priv
and sudo nmtui, edit connection, wired connection, edit ipv4 configuration,  Manual (Shared) 192.168.4.1/24, ok
Edited by denni_isl
