When executing a command -  sudo opt upgrade - returns an error:
Setting up linux-image-legacy-rk35xx (23.11.1) ...
Armbian 'linux-image-legacy-rk35xx' for '5.10.160-legacy-rk35xx': 'postinst' sta
rting.
 * dkms: running auto installation service for kernel 5.10.160-legacy-rk35xx
        [ OK ]
update-initramfs: Generating /boot/initrd.img-5.10.160-legacy-rk35xx
W: Possible missing firmware /lib/firmware/rtl_nic/rtl8125a-3.fw for module r816
9
W: Possible missing firmware /lib/firmware/rtl_nic/rtl8107e-2.fw for module r816
9
W: Possible missing firmware /lib/firmware/rtl_nic/rtl8107e-1.fw for module r816
9
W: Possible missing firmware /lib/firmware/rtl_nic/rtl8168fp-3.fw for module r81
69
W: Possible missing firmware /lib/firmware/rtl_nic/rtl8168h-1.fw for module r816
9
W: Possible missing firmware /lib/firmware/rtl_nic/rtl8168g-3.fw for module r816
9
W: Possible missing firmware /lib/firmware/rtl_nic/rtl8168g-2.fw for module r816
9
W: Possible missing firmware /lib/firmware/rtl_nic/rtl8106e-2.fw for module r816
9
W: Possible missing firmware /lib/firmware/rtl_nic/rtl8106e-1.fw for module r816
9
W: Possible missing firmware /lib/firmware/rtl_nic/rtl8411-2.fw for module r8169
W: Possible missing firmware /lib/firmware/rtl_nic/rtl8411-1.fw for module r8169
W: Possible missing firmware /lib/firmware/rtl_nic/rtl8402-1.fw for module r8169
W: Possible missing firmware /lib/firmware/rtl_nic/rtl8168f-2.fw for module r816
9
W: Possible missing firmware /lib/firmware/rtl_nic/rtl8168f-1.fw for module r816
9
W: Possible missing firmware /lib/firmware/rtl_nic/rtl8105e-1.fw for module r816
9
W: Possible missing firmware /lib/firmware/rtl_nic/rtl8168e-3.fw for module r816
9
W: Possible missing firmware /lib/firmware/rtl_nic/rtl8168e-2.fw for module r816
9
W: Possible missing firmware /lib/firmware/rtl_nic/rtl8168e-1.fw for module r816
9
W: Possible missing firmware /lib/firmware/rtl_nic/rtl8168d-2.fw for module r816
9
W: Possible missing firmware /lib/firmware/rtl_nic/rtl8168d-1.fw for module r816
9
gzip: stdout: No space left on device
E: mkinitramfs failure gzip 1
update-initramfs: failed for /boot/initrd.img-5.10.160-legacy-rk35xx with 1.
run-parts: /etc/kernel/postinst.d/initramfs-tools exited with return code 1
Free space after deleting the package linux-image-legacy-rk35xx in /boot:  3.6M
dpkg: error processing package linux-image-legacy-rk35xx (--configure):
 installed linux-image-legacy-rk35xx package post-installation script subprocess
 returned error exit status 1
Errors were encountered while processing:
E: Sub-process /usr/bin/dpkg returned an error code (1)
what could be the problem and how to fix it?
3 часа назад, MakKou86 сказал:
There is not enough space on the disk that is mounted in the /boot folder.
df -h
ls -al /boot
this will give you a hint
Thanks for the advice. Perhaps the problem arose because of the mirror - fastmirror.pp.ua. I am from Russia and perhaps because of this, not all packages could not stop properly, since the logs constantly had problems downloading from this mirror.
If you replace the url in the /etc/apt/sources.list.d/arm bin.list file http://apt.armbian.com on http://mirror .yandex.ru/mirrors/armbian/apt then the problem will be solved (I took it with 4pda).
Edited by MakKou86
