Hi all,
I am trying to get an OV5640 camera working on the orangePiOne. I found this thread
and was wondering if the overlay (or some overlay) is still required.
Without anything extra, the camera is not detected. It says that sun6i-csi and ov5640 kernel modules should be loaded, so I loaded them manually with modprobe but nothing happens and nothing is shown in dmesg.
Adding the mentioned overlay with  "sudo armbian-add-overlay csi-ov5640.dts" just gives me an error in dmesg at reboot time
"failed on fdt_overlay_apply(): FDT_ERR_NOTFOUND
Error applying DT overlays, restoring original DT"
uname -a
Linux orangepione2 6.1.63-current-sunxi #1 SMP Mon Nov 20 10:52:19 UTC 2023 armv7l GNU/Linux
boot logs on https://paste.armbian.com/unoqesepov
wondering what to try next...
Edited by bschwand
thanks, I tried that overlay now and there is some progress. A new device appeared in /dev/video, and I can see with lsmod that sun6i-csi and ov5640 kernel modules were loaded.
However, trying ustreamer (https://github.com/pikvm/ustreamer) which I have used on the same board with a usb camera, unfortunately fails
bruno@orangepione2:~$ sudo ustreamer --device=/dev/video0 --host=0.0.0.0 --port=8080 --resolution 1920x1080
-- INFO  [680.044      main] -- Using internal blank placeholder
-- INFO  [680.045      main] -- Listening HTTP on [0.0.0.0]:8080
-- INFO  [680.046    stream] -- Using V4L2 device: /dev/video0
-- INFO  [680.046    stream] -- Using desired FPS: 0
-- INFO  [680.047      http] -- Starting HTTP eventloop ...
-- INFO  [680.049    stream] -- Device fd=8 opened
-- INFO  [680.049    stream] -- Using input channel: 0
-- INFO  [680.049    stream] -- Using resolution: 1920x1080
-- INFO  [680.049    stream] -- Using pixelformat: YUYV
-- INFO  [680.050    stream] -- Querying HW FPS changing is not supported
-- INFO  [680.050    stream] -- Using IO method: MMAP
-- INFO  [680.075    stream] -- Requested 5 device buffers, got 5
-- ERROR [680.076    stream] -- Unable to start capturing: Broken pipe
-- INFO  [680.081    stream] -- Device fd=8 closed
-- INFO  [680.081    stream] -- Sleeping 1 seconds before new stream init ...
I am going to try other formats, sizes and fps, see if it makes any difference...
I found the program v4l2-compliance
it has one failure :
Format ioctls (Input 0):
                fail: v4l2-test-formats.cpp(263): fmtdesc.description mismatch: was 'Y/UV 4:2:0 (16x16 Linear)', expected 'Y/CbCr 4:2:0 (16x16 Linear)'
        test VIDIOC_ENUM_FMT/FRAMESIZES/FRAMEINTERVALS: FAIL
also very strange, I expected output like this
instead I get this
bruno@orangepione2:~$ v4l2-ctl -d 1 --list-ctrls --list-formats
ioctl: VIDIOC_ENUM_FMT
        Type: Video Capture
        [0]: 'BA81' (8-bit Bayer BGBG/GRGR)
        [1]: 'GBRG' (8-bit Bayer GBGB/RGRG)
        [2]: 'GRBG' (8-bit Bayer GRGR/BGBG)
        [3]: 'RGGB' (8-bit Bayer RGRG/GBGB)
        [4]: 'BG10' (10-bit Bayer BGBG/GRGR)
        [5]: 'GB10' (10-bit Bayer GBGB/RGRG)
        [6]: 'BA10' (10-bit Bayer GRGR/BGBG)
        [7]: 'RG10' (10-bit Bayer RGRG/GBGB)
        [8]: 'BG12' (12-bit Bayer BGBG/GRGR)
        [9]: 'GB12' (12-bit Bayer GBGB/RGRG)
        [10]: 'BA12' (12-bit Bayer GRGR/BGBG)
        [11]: 'RG12' (12-bit Bayer RGRG/GBGB)
        [12]: 'YUYV' (YUYV 4:2:2)
        [13]: 'YVYU' (YVYU 4:2:2)
        [14]: 'UYVY' (UYVY 4:2:2)
        [15]: 'VYUY' (VYUY 4:2:2)
        [16]: 'RGBP' (16-bit RGB 5-6-5)
        [17]: 'RGBO' (16-bit A/XRGB 1-5-5-5)
        [18]: 'HM12' (Y/UV 4:2:0 (16x16 Linear))
        [19]: 'NV12' (Y/UV 4:2:0)
        [20]: 'NV21' (Y/VU 4:2:0)
        [21]: 'YU12' (Planar YUV 4:2:0)
        [22]: 'YV12' (Planar YVU 4:2:0)
        [23]: 'NV16' (Y/UV 4:2:2)
        [24]: 'NV61' (Y/VU 4:2:2)
        [25]: '422P' (Planar YUV 4:2:2)
        [26]: 'RGBP' (16-bit RGB 5-6-5)
        [27]: 'RGBR' (16-bit RGB 5-6-5 BE)
        [28]: 'JPEG' (JFIF JPEG, compressed)
also
bruno@orangepione2:~$ media-ctl -d 0 --print-topology
Media controller API version 6.1.63
Media device information
driver          sun6i-csi
model           Allwinner A31 CSI Device
serial
bus info        platform:1cb0000.camera
hw revision     0x0
driver version  6.1.63
Device topology
- entity 1: sun6i-csi (1 pad, 1 link)
            type Node subtype V4L flags 0
            device node name /dev/video1
        pad0: Sink
                <- "ov5640 1-003c":0 [ENABLED]
- entity 5: ov5640 1-003c (1 pad, 1 link)
            type V4L2 subdev subtype Sensor flags 0
            device node name /dev/v4l-subdev0
        pad0: Source
                [fmt:UYVY8_2X8/640x480@1/30 field:none colorspace:srgb xfer:srgb ycbcr:601 quantization:full-range
                 crop.bounds:(0,0)/2624x1964
                 crop:(0,4)/2624x1944]
                -> "sun6i-csi":0 [ENABLED]
Edited by bschwand
