ezpc98 Posted February 1, 2024 Posted February 1, 2024 (edited) Armbianmonitor: https://paste.armbian.com/ujepidafuq I'm new to SBC and tinkering with Rock 4C+ (plus) board and appreciate some support and guidance for blueooth setup. Installed Armbian 23.11.1 Bookworm CLI build. Enabled BT package from Armbian config utility as well tried installing bluez package from CLI using apt command afterwards. Started bluetooth service but seems not working. Command sequence I used: sudo apt install bluez sudo service bluetooth start sudo service bluetooth status (output says Loaded & Active). 'hcitool scan' command however returns message "Device is not available: No such device". When I installed Radxa's official Debian 11 desktop build, bluetooth works out of the box. I can see bluetooth connection icon in system tray and active. What I'm doing wrong or missing to setup bluetooth on Armbian bookworm build? Edited February 1, 2024 by ezpc98 Added ref to Armbian build version I'm using 0 Quote
